Author Topic: How do you deal with using MAME in 2 different rooms?  (Read 2868 times)
j123vt_99
  • Last login:August 24, 2006, 09:41:12 am
« on: March 11, 2005, 02:43:39 pm »
Like most of you, i will be building a mame machine in the near future. currently i have mame and other emus on a HD in my comp. I think I want to keep mame and emus on my comp as well so i can play a quick game every now and then.. do you guys just use seperate HDs or do you network the cab and PC together and work off a server environment?
Pictures of my Missile Command  http://www.nimsu.com/mc/mc.html
Buddabing
Re: How do you deal with using MAME in 2 different rooms?
« Reply #1 on: March 11, 2005, 02:55:11 pm »
Separate PCs. My cab runs MAME v0.78. If it ain't broke, don't fix it. On my regular computer I have my custom MAME build.
Please read the wiki!
j123vt_99
« Reply #2 on: March 11, 2005, 03:01:23 pm »
and when there is an upgrade to roms or mame?
SirPeale
  • Green Mountain Man
« Reply #3 on: March 11, 2005, 03:07:19 pm »
Like the man said, "If it ain't broke, don't fix it."  However, if a future version of Mame supports a new game, just copy the new exe and ROM to your drive on your cabinet.  Make a backup of the old exe, JIC.  Play with it.  If you like it, then run ClrMAME on the cab to clear up any potential changes.
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
« Reply #4 on: March 11, 2005, 03:07:28 pm »
Network the PCs and use a remote admin software so that you dont have to switch rooms to see how something is working.
j123vt_99
« Reply #5 on: March 11, 2005, 03:09:44 pm »
thanks for the quick reply guys... peale & budda, what are the specs on the comps you are using in your cab?
SirPeale
« Reply #6 on: March 11, 2005, 03:11:47 pm »
AMD K6/2 550 (which is only recognized as a 450) and a I forget the other.  I think it's about 400 MHz.  Oh, and a 486 I'm about to upgrade to a P133.
j123vt_99
« Reply #7 on: March 11, 2005, 03:12:49 pm »
K6 slower than a Athlon/Duron?
Buddabing
« Reply #8 on: March 11, 2005, 03:15:16 pm »
FIC AZ11E motherboard
Duron 900 MHz
384 MB SDR DRAM
ArcadeVGA
Pentranic 1425 25" arcade monitor
Windows XP Pro SP2 (bleccch, I would rather use DOS)
SB Live! Value
MAMEWah
brandon
  • Last login:December 26, 2025, 08:29:45 pm
  • I <3 arcade games.
« Reply #9 on: March 11, 2005, 03:21:43 pm »
for sure.. slower than Pentium II AFAIK  probably work just fine with older build of Mame and classic games though.
« Last Edit: March 11, 2005, 03:31:35 pm by brandon »
SirPeale
« Reply #10 on: March 11, 2005, 03:33:28 pm »
Actually about the same speed.
Buddabing
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #12 on: March 11, 2005, 05:29:18 pm »
my roms are stored on my mame machine.  I network map a drive letter on my arcade machine.
Fat_Trucker
  • Last login:September 08, 2010, 11:44:22 am
« Reply #13 on: March 11, 2005, 05:54:47 pm »
Yup. Have a seperate PC in my cab (actually used it as an excuse to upgrade my desktop pc and just used my old one).
Everything is installed seperately inside the cab and you simply open the coin door to access the dvd drive for updating etc.
Some people use a wireless network card so they can update their cab remotely.
Cab PC:
AMD Athlon 2800XP (2.2Ghz)
80 Gb Maxtor HDD
Arcade VGA from Ultimarc
Soundblaster Live soundcard
512Mb PC3200 DDR
MSI DVD Rom.
Running Win XP and Command line MAME with MameWah FE.
I didn't touch it....honest!
paigeoliver
  • Awesome face!
« Reply #14 on: March 11, 2005, 08:32:05 pm »
I never ever, ever update anything in my cabinets, once the machine is done it is closed up and never updated. Updates are just trouble, can break what previously worked, and make games that previously ran full speed fun slower. Sure it won't matter much for a few updates, but after a few years your cab will be crappy and slow.
