Author Topic: Squished picture problem.  (Read 2172 times)
slicer_d
  • Last login:November 06, 2013, 12:51:11 am
  • Yay n' stuff
« on: March 10, 2005, 01:39:39 am »
Hey guys just got a new cabinet (Run and Gun 2) and its all good except that the picture is squished.
« Last Edit: March 10, 2005, 05:28:55 am by slicer_d »
Ken Layton
  • Guru
  • Technician
Re: Squished bicture problem.
« Reply #1 on: March 10, 2005, 02:02:42 am »
If adjusting vertical size/height and the 50/60 hz pot doesn't help then your monitor probably needs a capkit.
slicer_d
  • Yay n' stuff
« Reply #2 on: March 10, 2005, 04:12:13 am »
Yeah figured it might be that.  A couple more things I only have 5 video wires running to the board R,G,B, Hsync, and Ground should I have a Vsync or is it carried on one of the other wires?
One more question.  Do I have a vertical size problem or horizontal size problem? The screen in horizontal and there are 2-3" gaps at the top and bottom.
Ken Layton
  • Guru
  • Technician
Re: Squished picture problem.
« Reply #3 on: March 10, 2005, 10:22:16 am »
Monitor problems are described just like the way a normal tv set would be watched so you have a vertical problem if the top/bottom are affected.
Your monitor's video/sync input is wired correctly. Not every monitor nor gameboard needs the vertical sync hooked up.
slicer_d
  • Yay n' stuff
« Reply #4 on: March 10, 2005, 04:14:52 pm »
So i guess I need to do the cap kit then I was looking through bob roberts site and he has cap kits of K7000's and mine is a k7191 so is that the kit I should get?
Also I was reading around about vertical output transistors going bad and causing similar problems to what I have should I replace those as well?
Oh and thanks for the help guys (guys = Ken)
menace
« Reply #5 on: March 10, 2005, 04:39:02 pm »
I had a similar problem and replaced IC2 and that seemed to cure it.  But by all means do the cap kit first--it needs to be done anyways and it might solve your problem.
Ken Layton
  • Guru
  • Technician
« Reply #6 on: March 10, 2005, 06:35:46 pm »
Yes, a k7000 kit is the one to use on a 7191. This model does not use vertical output transistors. It has a tiny integrated circuit (IC3) bolted to a metal heat sink for the vertical output stage. Sometimes both IC2 and IC3 go bad.
slicer_d
  • Yay n' stuff
« Reply #7 on: March 10, 2005, 08:32:03 pm »
I figure if I'm going to take the trouble of taking the entire monitor out I might as well replace anthing that might need replacing soon.
« Last Edit: March 10, 2005, 09:21:35 pm by slicer_d »
slicer_d
  • Yay n' stuff
« Reply #8 on: March 16, 2005, 06:28:41 am »
I guess I'm just going to get the cap kit, IC2 and IC3.  I dont know if IC3 is worth getting at 11 bucks its kind of expensive should I get it just in case?
