Author Topic: Can mame recognize 2 mouse buttons?  (Read 2235 times)
the3eyedblindman
  • Last login:November 17, 2006, 03:00:06 pm
  • Soon: 4 Player Mame and Scratch Built Moonwalker.
« on: March 09, 2005, 09:05:49 pm »
I tried setting up 1 button for left mouse and 1 button for right mouse but both mouse keys are recognized as "mouse button zero" Is there any way to program to mouse buttons into mame?
Coming soon: 4 player mame cab and Scratch built Moonwalker....Hall of Fame, here I come!
GGKoul
  • Cheesecake Apprentice
Re: Can mame recognize 2 mouse buttons?
« Reply #1 on: March 09, 2005, 09:41:23 pm »
If you have Opti-pac it will...
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: March 10, 2005, 01:37:46 am »
yes.
Oh, you really mean "Can mame recognize 2 mice as seperate mice?"
The short answer is not really, but . . .
If you use button 1 on one mouse and button 2 on the other, it's fine.
Otherwise, you'll need to use ver. 0.83 of mameAnalog+ (sorry about it not up to date ATM) if you're using winXP.
WinME/98 is a little different (might work on official mame), but I won't go into the details if you don't have that OS.
Robin
Knowledge is Power
daywane
  • GRRRR!
« Reply #3 on: March 10, 2005, 08:58:56 am »
I read it as your Mame will not see your right and left buttons one a single mouse?
you have a driver problem.
If this is the case I will try and find a program i had to down load ( I mean huge for a driver) ( took me 1 hr to download it)
I had  a kind of the same problem.
only I needed the mid button to work on a three button mouse. Some one at emuadvice helped me out.
If this is your problem let me know because it might take me some time to find out what driver that was.
driver might be a wrong word. lets go with program for now.
It boils down to ... I was able to remap the buttons on my mouse to be what ever I wanted them to be
fogman
  • Last login:June 09, 2007, 03:56:32 pm
  • A Tale of Nocturnal Terror!!!
« Reply #4 on: March 10, 2005, 09:49:21 am »
For some reason, I have had this problem with various builds of Mame.  For example, I was going crazy trying to get all three mouse buttons to work, but as you said, two of my buttons kept coming up as Mouse 0.  I was using an Optimized build at the time.  When I went back to straight Mame, the problem went away.
Let me know if you have tried a different build of mame to see if this fixes it.  I am curious as to whether this was what fixed mine, or a combination of things that I did.
Chris
    • Chris's MAME Cabinet
« Reply #5 on: March 10, 2005, 10:45:18 am »
Are you planning to continue the project?  I really miss my dual lightguns...
--Chris
the3eyedblindman
« Reply #6 on: March 10, 2005, 02:21:23 pm »
I didn't  mean 2 mice, i meant both mouse buttons on the same mouse. I am using mame32 version 92, and when I go to tab to set buttons as mouse buttons, they both show up as "mouse button zero" and each click does the same function.
crashwg
« Reply #7 on: March 10, 2005, 05:36:49 pm »
Are you pausing the game before you change the settings?  If you are, don't.
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
