Author Topic: Simple Shinobi questions  (Read 4763 times)
VooDoo
  • Last login:March 10, 2005, 10:05:02 pm
« on: March 07, 2005, 09:52:16 am »
Quick questions.  I picked up a shinobi at the Knoxville Auction, working for a cheap price.  I brought it home and it won't comeup.  The LED on the mainboard comes up, the monitor tubes are lit (from the back) and I can hear the faint buzz from the sound coming up.  That is about it.
I am thinking that something went wrong in the transport, but have no idea where to start on these sega 16 cabs.
Can someone give me advice of what I should do or where I should start?
Thanks in advacne
Ken Layton
  • Guru
  • Technician
Re: Simple Shinobi questions
« Reply #1 on: March 07, 2005, 10:12:47 am »
Did the gameboard edge connector come loose or cock-eyed? Any loose socketed IC chips? The game power supply working properly? Just because the LED is lit doesn't mean the voltage is good from the power supply. Remember that Shinobi is not a Jamma standard game (unless of course someone installed a Shinobi to Jamma adapter on the board).
Get  multimeter and measure all the voltages from the power supply.
VooDoo
« Reply #2 on: March 07, 2005, 10:42:06 am »
Good idea, I need to find the manual etc. on line then and find out what those voltage numbers should be
fredster
  • It's all good!
« Reply #3 on: March 07, 2005, 05:37:27 pm »
Probably something loose. Reseat the harness.  Shinobi's usually live well.
System 16 looks the same as Jamma, but it aint.
That was in that Robotron Cab wasn't it?  Has a WG 4900 for a monitor?
Check all the connections to make sure they are tight, fire it up, and then take your hand and tap the board and wait for a second.  Do it a couple of times.
I'm not kidding.  I'm very serious.  If it comes up, you have some loose chips on that board or wires.  Then you would take it out and reseat the roms.
Lots of places on the net to find the manual.  Mikesarcade.com is one of them.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #4 on: March 07, 2005, 06:20:09 pm »
Don't use a long extension cord.
And did you see the game working before you brought it home?
NO MORE!!
VooDoo
« Reply #5 on: March 07, 2005, 06:22:23 pm »
Fredster,
Not too sure about the cab, I didn't really look.
RayB
  • There's my post
    • RayB.com
« Reply #6 on: March 07, 2005, 06:30:33 pm »
If it was working, your voltage is probably fine. Just check all connections first, and don't use one of those long outdoor lawnmower extension cords.
(And try coining it up, see if you hear any sound)
NO MORE!!
VooDoo
« Reply #7 on: March 07, 2005, 09:50:06 pm »
Thanks all, I will give it a try in the next day or so and post results - I hope it will just be another thank you and not asking for more ideas :)
VooDoo
« Reply #8 on: March 08, 2005, 08:21:52 pm »
Well the DC was coming out at almost 15V, as the board wants 12V this was a problem.
Adjusted down to 12.05V and all is good.
Thanks everyone.
