Author Topic: Golden Axe Player 2 problem  (Read 1191 times)
ScottMcC
  • Last login:January 07, 2006, 12:47:07 am
« on: March 05, 2005, 11:34:33 pm »
I
elvis
  • Last login:January 13, 2025, 08:48:40 am
  • penguin poker
    • StickFreaks
Re: Golden Axe Player 2 problem
« Reply #1 on: March 06, 2005, 02:25:27 am »
Try deleting the contents of your nvram and cfg folders under your main MAME folder.  Warning: this will reset everything to defaults - including all key mappings, resolution settings, etc.  If you want to just test this, then move them somewhere temporary rather than deleting them.
Some games get updates to their code from version to version (much change is happening in SEGA code at the moment), and old configurations won't work well with new versions.
If that fails, then head over to MAMETesters and see if it's an official bug.  Failing that, the MAME forums themselves.
http://www.mametesters.org/
ScottMcC
« Reply #2 on: March 06, 2005, 03:54:06 pm »
I tried running with configs and nvram gone and had no luck.  Checked out testers and my problem is not a bug.  In fact no seems to ever have had my problem which make me think it must be something on my set up but I can figure out what.  Is anyone running Golden Axe on .92?
