Author Topic: Bending lexan for Control Panel overlay  (Read 7930 times)
liche
  • Last login:November 13, 2007, 08:05:18 am
  • This is my BOOMSTICK!
« on: October 31, 2002, 12:00:41 pm »
I'm planning on putting lexan (or plexiglass) over my overlay on my control panel.  However, my control panel has a 90 degree bend (controls on top and front side).
A lot of people use acrylic and a heatgun to bend the acrylic to the shape of the control panel for a one piece cover, but I hate acrylic since its extremely difficult to machine compared to other types of plastics.
Anyone have luck with bending lexan or plexiglass??  I assume the plastic has to be thermoplastic which i think lexan (polycarbonate is) however the melting temperature is probably much higher than acrylic.
Any thoughts????
Elkor
  • Last login:February 12, 2007, 12:42:50 pm
  • What did I just say?
    • Full Circuit
Re:Bending lexan for Control Panel overlay
« Reply #1 on: October 31, 2002, 12:44:07 pm »
Yeah, you can thermoform it.  Don't know what kind of temp you would need though.  It's probably not as bad as you'd think...
some info:
http://www.mcmaster.com/param/asp/loadaddcontent.asp?ID=100000000904758250020000
-C
The sudden sight of me causes panic in the streets. They have yet to learn
-- only the savage fears what he does not understand.
                -- The Silver Surfer
ErikRuud
  • Last login:March 23, 2026, 07:42:27 pm
« Reply #2 on: November 01, 2002, 03:43:33 pm »
PlexiGlass is an acrylic.
Lexan can be tricky stuff to form.  I know people that use it for slot car and R/C car bodies.  Of course you would be using thicker material that they do.  Lexan has a tendancy to absorb moisture.  It's not a lot, but that moisture can cause problems, because the Lexan needs to be heated above the boiling point of water.  Before thermo forming lexan, you need to dry it for a while.  150 degress is a good temp to dry it at.
If I remember correctly, 450 degrees is the temp used to vac-u-form lexan. To do a simple bend, you won't need to go that high.
Experiment with some scraps.
American Laser Games Wrapper
O2em Rom Utility
SNAAAKE
  • -Banned-
« Reply #3 on: November 04, 2002, 07:23:34 pm »
while we are at it :).
Is it possible to bend laminate because I wanted know how.I saw some bent laminate in a restaurent once and looked very cool.
Anyone ??? ::) ????
ErikRuud
« Reply #4 on: November 05, 2002, 10:14:12 am »
I'm pretty sure that bending laminate needs some pretty special equipment.  A very gentle curve may be possible, but anything else would be very hard to do.
My wife used to work for a countertop frabicator.  They did not bend laminate.  It was either flat, or formed at the factory.  On the other hand the did some pretty amazing stuff with solid surface materials like Corian and Avonite.
O2em Rom Utility
SNAAAKE
  • -Banned-
« Reply #5 on: November 05, 2002, 01:41:48 pm »
ehh :P
Seems a lot of work so I wont even try but thanks for the answer though ;)
_Iz-
  • Last login:May 19, 2026, 09:24:45 pm
  • Time to coin up!
« Reply #6 on: November 05, 2002, 01:58:10 pm »
Liche, I recently read an article on case modding. The author bent lexan by heating it in his oven at 375
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #7 on: November 05, 2002, 11:07:53 pm »
It also depends on what laminate you use.  Some are designed for some bending. WilsonArts, and laminate sold at HomeDepot, has different types of laminate, some designed for bending.  http://www.wilsonart.com/laminate/consumer/product_support/q_a_results.asp?id=34  The stuff at HomeDepot, however, is the non-bendable type.
Robin
Knowledge is Power
_Iz-
  • Time to coin up!
« Reply #8 on: November 06, 2002, 01:00:15 pm »
Postforming grade is bendable. (Really tight curves require special equipment and heat. General purpose is thicker and not recommended for bending.
liche
« Reply #9 on: November 06, 2002, 02:42:26 pm »
_IZ_
If you can find that link regarding bending LEXAN in the oven, let me know.
_Iz-
  • Time to coin up!
« Reply #10 on: November 06, 2002, 05:27:04 pm »
http://www.designmethod.com/bling/
Click on Version.2
It's steps 7 & 8.
Temp is 325
