Author Topic: Pinmame?  (Read 1668 times)
the3eyedblindman
  • Last login:November 17, 2006, 03:00:06 pm
  • Soon: 4 Player Mame and Scratch Built Moonwalker.
Pinmame?
« on: February 25, 2005, 06:02:08 pm »
Just a question about pinmame, I dont really understand it..Is it like a virtual pinball table of a real pinball machine that u play on, or does it just emulate the score screens of the game?
Coming soon: 4 player mame cab and Scratch built Moonwalker....Hall of Fame, here I come!
wpcmame
  • Last login:February 18, 2024, 01:27:00 pm
Re: Pinmame?
« Reply #1 on: February 26, 2005, 05:46:40 am »
Pinmame just emulates the hardware and the score screens in the pinball backbox.
BUT!. There is another program, Visual Pinball, that allows you to create and play pinball tables.
The good thing here is that it is possible to combine the two programs so that Visual Pinball plays the table and pinmame controls the scores and lamps etc.
The bad thing is that it is still two programs developed by completly different teams and where one (Visual Pinball) isn't open source. This means that it is complicated to get everything running. You need to collect a lot of parts and install them in the correct folders before it works.
(It is a long story why it is like that but the main reason is about copyright)
Read all about it and get help here www.vpforums.com
Gunstar Hero
  • Last login:September 28, 2014, 01:51:17 am
  • Back in action!
Re: Pinmame?
« Reply #2 on: February 26, 2005, 01:35:13 pm »
http://www.pinballsim.com/
This site makes it easier.  ;D
KHAN
  • Last login:March 28, 2005, 05:14:27 pm
Re: Pinmame?
« Reply #3 on: February 26, 2005, 06:00:49 pm »
The Pinball emulation scene is made up of two seperate programs, which very cleverly work together.
Therefore you need to get hold over a program called Visual Pinball - Homepage - http://www.randydavis.com/vp/
This allows you to create and play computer versions of pinball tables. (extension is .VPT)
The second program is called PinMAME, this is based on MAME and allow roms from the pinball tables to be viewed and in some cases played. - Homepage - http://www.pinmame.com/
You'll need to download a program called Visual PinMAME (v1.32)
Install these two programs and then run the setup.exe program in the Visual PinMAME folder. This effectively creates a link between the two programs.
Now onto the tables.
There are two types of Tables. Ones that use the Roms and ones that are either so older that they didn't exist then or tables that people have created themselves. These are in the VisualPinballTables folder.
The second folder VisualPinMAMETables Folder. These are tables that require ROMS.
And the Roms are in the PinMAME folder.
so to play a table like the Adams Family you'll need the file from the VisualPinMAME folder and the rom from PinMAME.
You will also need some VBS scripts which are available in the folders.
You can then load Visual Pinabll, open a downloaded table (VPT file) and then select run. This will launch the table and it will tie in with the ROM, very cleaver really.
Hope this helps.
(And for a true cross over between MAME and Pinball check out Baby PacMan!)
« Last Edit: February 26, 2005, 06:03:59 pm by KHAN »
BLUE BIRDS FLY WITH BLUE BIRDS
