Author Topic: FE-3Darcade/Emulaxian 0.70 released!  (Read 2209 times)
)p(
  • Last login:March 27, 2009, 03:38:15 am
  • We are the Galaxians...
    • Emulaxian:cabinet and frontend
« on: October 29, 2002, 01:38:38 pm »
I added a lot of animation related stuff under the hood...that should make it possible to do some very funky stuff in the near future : ;D
Whatisnew:
0.70:
-Full animation support on all models! The arcade environment model and all models in it can now be fully animated!
-Animation can be played automatically, triggered when the model is selected and when the start key is hit.
-Custom event sounds when an animation is triggered.
-Support for additional models that not represent a gamelist entry. Ideal for non player characters and sliding doors etc.
-Proper support for additional lights attached to models of the arcade environments and non gamelist models.
-A scrolling listbox...yuck, not for me...I enabled it this time and only this time in the default skin for the gamelist menu: gllisttype|scrolling| I suggest go back to the normal one fast: gllisttype|paging| ;-)
-Replaced the runhidden property in emulator cfg files with a runmethod property that can take any of the normal launching methods.
-Speechvoice property to select a different voice for the speech function in the fe.
-Renderfix property, try this if the fe reverts to software mode after running a game or you have problems running 3d games from the fe.
-Adjusted crc.exe to not use a custom delphi dll.
-Fixed jumping camera with mouselook enabled under windows 98.
-Enabled doing stuff in the background while running a game. This means the runstopsound and vp exit key options work again.
websites:
http://3darcade.mameworld.net
http://www.i-modernist.com/emulaxian
Peter, peter@i-modernist.com
