Author Topic: Couple quick questions... Wood etc..  (Read 9427 times)
chrisindfw
  • Last login:May 09, 2020, 05:57:34 pm
  • I drank what?
« on: February 25, 2005, 03:46:36 pm »
3/4" or 5/8"
crashwg
Re: Couple quick questions... Wood etc..
« Reply #1 on: February 25, 2005, 04:06:50 pm »
1)it's realy up to you, most "real" arcade machines are 3/4" though
2)MDF
3)Not quite sure how to answer this question without sounding like being a smartass... it's usually as simple as attaching hinges and a locking mechanism to a piece of material the size of your opening
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
NoOne=NBA=
« Reply #2 on: February 25, 2005, 04:38:39 pm »
3/4" or 5/8"  (I am using T-Molding)
I'd go 3/4" for a full size.
If you use 5/8" on anything other than a bartop, it will look too small.
MDF or Particle Board
MDF is better than particle board for almost any application.
It is nicer to work with, and doesn't fall apart like particle board.
I personally used plywood because it holds up even better than MDF.
Whats the best way to create the door for the back panel?
I used 1/4" plywood for all the non-essential pieces on mine (top/back/speaker housing/etc...).
RecycledPast
  • Last login:October 09, 2011, 09:14:47 pm
    • My 2 scratch built arcade machines
« Reply #3 on: February 25, 2005, 04:41:25 pm »
1)
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #4 on: February 25, 2005, 04:52:30 pm »
If you are painting use MDF.  If you are laminating (highly recommended if you have the money.  Easy and superior looking) use plywood.  Don't use particle board or MDF if you don't have to.  Both are very heavy and paritcle board falls apart.  Even industrial strength particle board will not hold up like plywood (I could be wrong on that) and it's WAY heavier.
A single 8' by 4' sheet of MDF weighs upwards of 1 million pounds.
Best Kid iPad Apps
