Author Topic: MARQUEE size for TAITO cabinet  (Read 3479 times)
liche
  • Last login:November 13, 2007, 08:05:18 am
  • This is my BOOMSTICK!
« on: October 29, 2002, 10:34:01 am »
Hello,
I'm currently at work and have no way to measure my marquee size for my TAITO cabinet (yeah, i should have done that yesterday before work), but I need to order some plexiglass today for it.
Does anyone know what the standard marquee size is for a TAITO cabinet??
L
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:MARQUEE size for TAITO cabinet
« Reply #1 on: October 29, 2002, 10:45:12 am »
I *think* its like 22.5" x 8" or the like... off the top of my head.  I wouldn't order based on that, but I *think* that's what I measured mine at (it even has the taito little embossed label in the corner of the marquee glass.
Would it be enough to find a taito cab's marquee scan and see the print size and guess slightly larger for the glass?
does klov have this info?
*shrug*  I can of course measure from home, but seems like that would be too late for you...
rampy
ashardin
  • Last login:December 19, 2007, 07:43:09 pm
« Reply #2 on: October 29, 2002, 01:24:16 pm »
rampy sounds correctL
It is 23 inches side to side inside the cabinet.  22.5 sounds right so you get a 1/4 of play on each end.
Off the top of my head I though the top was 8.5 inches, since there is the slot to up the top of the marquee to insert the glass, but it may be 8 as well.
_Iz-
  • Last login:Yesterday at 10:35:57 pm
  • Time to coin up!
« Reply #3 on: October 29, 2002, 01:42:44 pm »
My cabinet is 23" wide inside exactly. 22.5" wide for the Marquee seems too narrow, 1/4" play each side would be WAYYY too much. I'd order it 22 7/8" wide, 1/16" play each side or even slightly tighter like 22 15/16". The less gap the better or you will have major light coming out the ends...
rampy
  • *shrug*
« Reply #4 on: October 29, 2002, 07:59:28 pm »
I measured my glass (installed) just now... it's like 22 6/8" wide which does leave a little gap on either side... but it's the stock glass so... you could fit one just under 23" wide as Iz suggested.
I measured the height (installed) guesstimating for the groove/etc at between 6 3/4" and a wee bit under 7"  (not sure where I got the 8" in the original post)
I'm being lazy by not removing the glass to measure it, if those dimensions are lacking for you, I'll try and get off ---my bottom--- and remove the glass and measure it that way =P
rampy
