Author Topic: MAMEWAH FRONT END ADDING EMULATORS!  (Read 1225 times)
M.A.M.E Power
  • Last login:February 06, 2007, 04:25:59 pm
  • There Are So Many Games!
« on: February 23, 2005, 05:38:12 am »
Hi
I recently installed and have sucessfully configured Mamewah to play MAME and it works a treat. I have also sucessfully installed the modified GENS emulator and also an atari Jaguar (Tempest). These two emulators are appering in the menu in Mamewah.
However we I select the option to populate the games list no games are appearing I have the ini files pointing to the correct folder on the C:\drive any ideas to where I might be going wrong.
Also what file extension should these roms be in are they still in zip format.
Thanks in advance
Lea :'(
Brad
  • Last login:August 03, 2018, 05:43:23 pm
    • www.emuchrist.org
Re: MAMEWAH FRONT END ADDING EMULATORS!
« Reply #1 on: February 23, 2005, 05:49:06 am »
Have a look at the ini files from johns site. I'd say you have issues with the rom extension and the list format is all.
http://home.comcast.net/~cpviewer/index.html
Brad
M.A.M.E Power
« Reply #2 on: February 23, 2005, 04:44:33 pm »
Hey Brad
Thanks for the link will check it out tonight and see if I can sort it out!
Thanks again
Lea
