Author Topic: DB15 specifications ?  (Read 4030 times)
Jeehemdee
« on: October 26, 2002, 03:30:42 am »
I have a joystick extension cable whose DB15 ending is to be screwed to a plexi panel. So I have to "route" the plexi panel. Here is my question ;-)
Where could I find the DB15 specifications (not the pinout etc...) I mean the specifications/dimensions of the global shape (you know..that trapezoid shape).
So that I can be perfectly routed on the plexi, and that the DB15 perfectly fit in it.
I personaly tried the ISO site (international standard organization) where I indeed found it (DB15=ISO4903):
http://www.iso.ch/iso/en/CatalogueDetailPage.CatalogueDetail?CSNUMBER=10923&ICS1=35&ICS2=100&ICS3=10
But it's about 80 swiss franc to get the PDF !!
So if by chance someone would have the info ;-)
SirPoonga
  • Puck'em Up
  • Last login:Today at 03:00:59 am
  • The Bears Still Suck!
Re:DB15 specifications ?
« Reply #1 on: October 26, 2002, 03:59:15 am »
um, have a gamepad?  trace it!
liche
  • Last login:November 13, 2007, 08:05:18 am
  • This is my BOOMSTICK!
« Reply #2 on: October 26, 2002, 09:53:02 am »
D-Subminiature connectors are standard over a slew of manufacturers.  The standard sizes are 9, 15, 25, 37, 50 Pin.
You can get datasheets for any of these connectors most anywhere as this is the most common connectors ever built.
Just a search on Google lists a few thousand sites on D-Sub connectors.
For starters, check:
Amphenol connectors
ITT connectors
etc...
Look under d-subminiature and you will find what you need.
drabbit
  • Last login:November 26, 2002, 01:33:27 pm
  • Keeps playing, and playing.....
« Reply #3 on: October 26, 2002, 04:04:18 pm »
Here are datasheets from NorComp, they include all standard D-Sub connectors (9, 15, 25, 37, 50 pins)...
Male: http://rocky.digikey.com/WebLib/NorComp/Web%20Data/172-XXX-10X-XX1.pdf
Female: http://rocky.digikey.com/WebLib/NorComp/Web%20Data/172-XXX-20X-XX1.pdf
Hope this helps!
Jeehemdee
« Reply #4 on: October 26, 2002, 05:31:59 pm »
Thanks very much...that's exactly what I needed   ;)
Thanks for the link drabbit !!
