Author Topic: Stupid mame question  (Read 1674 times)
telengard
  • Last login:April 28, 2026, 11:37:11 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
« on: February 16, 2005, 01:26:55 am »
I just switched over to using "stock" mame from advancemame since my new computer's graphics chipset isn't supported.   :(
Anyway, a lot of games seem to start up with the wrong orientation.  For example, all of the Willaims horizontal games startup up vertical.  I created ini files for each game to keep them from doing that but I'm finding more and more that do it.  Would it help to post my mame.ini here?
thanks for any help
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
wpcmame
  • Last login:February 18, 2024, 01:27:00 pm
Re: Stupid mame question
« Reply #1 on: February 16, 2005, 03:05:58 am »
telengard
    • S T U R C A D E
« Reply #2 on: February 16, 2005, 11:15:29 pm »
I have done the same thing myself recently and it was really a step down in functionality (I'm still using advmenu). What I really miss is advmame's possiblity to change things at runtime and then save the settings to the rc file. In "stock" mame you need to use the keyboard all the time to edit the ini files.
I added a few things to my own mame build to make it easier:
- resolution ini files, e.g. "768x576H.ini" so I don't need an inifile for each game
- multiple configuration ".cfg" files
- "time_to_throttle" to skip game power on tests.
Ensure that none of the rotate options (norotate, ror, rol, autoror, autorol) are activated.
Yeah I miss advmame too.  I still use advmenu though.  I had spent a *lot* of time creating perfect modes but until I get a PCI video card that is supported for this new computer I have to use std mame.
Anyway, I checked an all the flags you mentioned are set to 0.  The flag that seems to make the orientation change is the hwstretch option.  I want it to stretch but still keep the original orientation.  The keepaspect flag had no effect.
Here's my mame.ini:
### mamepp.ini ###
### Frontend Related ###
clones                  1
### Windows path and directory options ###
rompath                 c:\mame_cab\mameroms
samplepath              c:\mame_cab\mamesnd\samples
# inipath               <NULL> (not set)
cfg_directory           cfg
nvram_directory         nvram
memcard_directory       memcard
input_directory         inp
hiscore_directory       hi
state_directory         sta
artwork_directory       c:\mame_cab\mameimg\artwork
snapshot_directory      c:\mame_cab\mameimg\snap
diff_directory          diff
ctrlr_directory         ctrlr
cheat_file              cheat.dat
history_file            history.dat
mameinfo_file           mameinfo.dat
### Windows video options ###
autoframeskip           0
frameskip               0
waitvsync               0
triplebuffer            0
window                  0
ddraw                   1
direct3d                0
hwstretch               1
cleanstretch            0
resolution              auto
refresh                 0
scanlines               1
switchres               1
switchbpp               1
maximize                1
keepaspect              0
matchrefresh            0
syncrefresh             0
throttle                1
full_screen_brightness  0.000000
frames_to_run           0
effect                  sharp
screen_aspect           4:3
### Windows Direct3D 2D video options ###
zoom                    2
d3dtexmanage            1
d3dfilter               0
d3dfeedback             0
d3dscan                 100
d3deffectrotate         1
d3dprescale             auto
d3deffect               none
# d3dcustom             <NULL> (not set)
# d3dexpert             <NULL> (not set)
### Windows misc options ###
sleep                   1
rdtsc                   0
high_priority           0
### Windows sound options ###
audio_latency           1
# wavwrite              <NULL> (not set)
### Input device options ###
mouse                   1
joystick                0
lightgun                0
dual_lightgun           0
offscreen_reload        0
steadykey               0
keyboard_leds           1
led_mode                ps/2
a2d_deadzone            0.300000
# ctrlr                 <NULL> (not set)
paddle_device           keyboard
adstick_device          keyboard
pedal_device            keyboard
dial_device             keyboard
trackball_device        keyboard
lightgun_device         keyboard
digital                 none
### Mame CORE video options ###
norotate                0
ror                     0
rol                     0
autoror                 0
autorol                 0
flipx                   0
flipy                   0
debug_resolution        auto
gamma                   0.750000
brightness              0.940000
pause_brightness        0.650000
### Mame CORE vector game options ###
antialias               1
translucency            1
beam                    1.000000
flicker                20.000000
intensity               3.000000
### Mame CORE sound options ###
samplerate              44100
samples                 1
resamplefilter          1
sound                   1
volume                  0
### Mame CORE misc options ###
artwork                 1
use_backdrops           1
use_overlays            1
use_bezels              1
artwork_crop            0
artwork_resolution      0
cheat                   0
debug                   0
# playback              <NULL> (not set)
# record                <NULL> (not set)
log                     0
maxlogsize              10000
oslog                   0
skip_disclaimer         1
skip_gameinfo           1
skip_validitychecks     0
crconly                 0
bios                    default
# state                 <NULL> (not set)
### Configuration options ###
readconfig              1
verbose                 0
telengard
    • S T U R C A D E
« Reply #3 on: February 17, 2005, 12:00:00 am »
So after about an hour or so of trying out toggling/changing different flags I figured it out.  Turning on direct3d fixed it.  I have **no** idea why turning on the 3D library would help with the orientation of a 2D game like Defender but it's working now so I'm happy.
Thanks for your help!
