Author Topic: light up control panel  (Read 2291 times)
sodapopinski
  • Last login:February 12, 2011, 11:13:41 am
  • if I only had normal friends
« on: February 16, 2005, 12:39:26 am »
I'd like to put some lights under my control panel and make it light up, much like the marquee. figure this is a good idea? or to many shadows of parts.
Stingray
Re: light up control panel
« Reply #1 on: February 16, 2005, 11:20:45 am »
So are you planning on making your CP out of just plexi with artwork under? Sounds like it would crack unless you used maybe 1/2 inch plexi. In any case I think you are correct, there's just too much stuff under there to be able to effectively light it it. The wiring alone would make this pretty impractical.
-S
Witchboard
« Reply #2 on: February 16, 2005, 11:28:55 am »
A better aproach might be similar to johnnysmitch's CAF arcade, but put the etched plexi on the CP instead of on the front.  It would be rather distracting though.  :-\
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
« Reply #3 on: February 16, 2005, 11:50:48 am »
Okay, to clear this up, if you want to light the whole thing like a marquee, you wouldnt be able to use the same type of lighting.  You would need to wire a ton of bulbs to the bottom of it to light shadowed parts.  It will be different lol, and may take away from the arcade if you planned on using lighted buttons AND/OR lighted trackballs.
krakboi
  • Last login:July 26, 2005, 05:41:46 pm
    • krakboi.com
« Reply #4 on: February 16, 2005, 12:39:12 pm »
What you need to do is find someone who has a Cosmic Chasm, and ask them how the CP is backlit.  This is going to be difficult because the game is very rare.  Here is a pic I took of one at CAX 2 years ago.
Santoro
  • Santoro
  • Trade Count: (+32)
  • Boycott Quarters!!!
    • ArcadeReplay!
« Reply #5 on: February 16, 2005, 01:50:38 pm »
Search, I remember seeing someone here that had 1/4" (1/2"?) Plexi and had lit the edge inside the cabinet, turned out pretty well.
sodapopinski
« Reply #6 on: February 16, 2005, 02:17:55 pm »
this plan certaily needs some re-evaluation, I didnt think about the strenght of the plexi. But, perhaps I could jigsaw out circles or other shapes then router a lip, place the plexi and light up areas of the control panel. Like the pinball play surface.
cholin
    • Nilok Productions
« Reply #7 on: February 16, 2005, 02:24:11 pm »
I bet you could, but I wouldnt risk it with plexi because it is asking for it to break.
Trimoor
  • Last login:November 18, 2006, 09:01:46 pm
  • I like shooting out of helicopters.
    • Trimoor
« Reply #8 on: February 16, 2005, 02:34:46 pm »
Use several layers of plex.  It will be much stronger.  You can even engrave the different layers for a 3D look.
spystyle
« Reply #9 on: February 16, 2005, 03:01:09 pm »
That's a good idea, stack lexan or acrylic to 3/4" and use printed transparancy paper as a CPO under the 1st layer.
Groovy
Chris
    • Chris's MAME Cabinet
« Reply #10 on: February 16, 2005, 03:26:05 pm »
Or just have the CPO printed on the same material the marquee is printed on.
You could also take the TRON approach, put a blacklight above the panel and highlight parts of the CPO with UV-reactive ink or paint.  (Aren't yellow highlighter pens UV reactive?)
--Chris
ErikRuud
  • Last login:March 23, 2026, 07:42:27 pm
« Reply #11 on: February 16, 2005, 03:41:38 pm »
I don't know if all yellow highlighters are UV reactive, but I do know that the UV reaction tends to fade over time.
Your best bet is to use products like these:
Terror By Design - Haunting Materials  (Near the bottom of the page)
American Laser Games Wrapper
O2em Rom Utility
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
« Reply #12 on: February 16, 2005, 04:17:32 pm »
You could illuminate the plexiglass itself by imbedding superbright LEDs in the top edge of it.
I created a mousepad with this effect after running across a similar project at this link which appears to no longer be operating....
http://www.metku.net
Of course, few mfrs picked up on the idea and created similar retail products like what is found here:
http://www.thinkgeek.com/computing/input/keyboards/6945/
Not backlit like marquee but makes for some cool lighting....
