Author Topic: pinmame window size?  (Read 4851 times)
sac01
  • Last login:February 27, 2016, 08:15:22 am
« on: February 13, 2005, 09:39:09 am »
I recently changed my cabinet monitor from an svga, to a larger vga (640x480 max) monitor...My question is, is there a way to make the pinmame score window smaller (lower res?) i tried setting to compact size, but that dosn't seem to work.  The scoreboard just takes up alot of room now, and is overlapping onto the table.
 Am i just basically stuck with it like this since i'm running at a low res?
thanks
sac
math0ne
  • Last login:January 21, 2025, 04:50:16 pm
Re: pinmame window size?
« Reply #1 on: February 13, 2005, 11:36:00 am »
Hmm... that seams to work for me.. i think you may have to restart pinmame.
also you could try vp-launch4 by the guy that makes dragon king.  it allows you to change the window size with a percentage.
sac01
« Reply #2 on: February 13, 2005, 11:41:16 am »
ah ok, yeah i use howards wrapper now, i'll look into it. I'm just happy to know it can be changed :)
do you mean reinstall pinmame? i know the docs say it uses the desktop resolution, but i think they mean it uses the resolution that was active on install.  since my desktop it 640x480 now and it dosn't seem to change to that for pinmame
sac
sac01
« Reply #3 on: February 13, 2005, 12:56:09 pm »
ok, setting howards wrapper to set pinmame display to 50% seemed to do the trick perfectly for everything but Baby Pacman, the videogame display on that is still too large, but all in all i can live with that.
thanks for the help :)
sac
