Author Topic: DOS Mouse Driver Supporting Changing Orientation  (Read 1352 times)
wakerlet
  • Last login:September 25, 2007, 11:37:53 am
  • 1-2-3-4..thats the combination on my luggage
« on: February 11, 2005, 02:58:48 pm »
Does anyone have a generic DOS mouse driver they would recommend that supports rotating the mouse orientation by 90 degrees?  I did something stupid when mounting my betson PS2 trackball and now it's 90 degrees off.  The problem is that I cannot just swap cables since the PS2 encoder is on one of the encoders.
Let me know if you have suggestions.
Thanks,
Todd
OSCAR
    • Oscar Controls
Re: DOS Mouse Driver Supporting Changing Orientation
« Reply #1 on: February 11, 2005, 03:38:49 pm »
Hi Todd,
http://www.oscarcontrols.com/files/MOUSE.EXE
Type 'mouse /?' at the command prompt to bring up all the options available.  I believe the flag for rotation is ORIENT x, where x is the number of degrees to rotate (0-359).  The first time you run the driver, it should make a mouse.ini file for the options, too.
Kelsey
wakerlet
« Reply #2 on: February 12, 2005, 09:36:44 pm »
Hi Todd,
