Author Topic: Superbright led's is there a guide on wiring and what i need to do?  (Read 2956 times)
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
I have bought some superbright led's from e-bay in the hope of lighting my coin door and trackball red for the door and blue for the ball. I have a spare psu form an old pc and was thinking of using that to power the lights.
Now not know ing anything about wiring i was wondering where to start and what consideration i have to take into account i know nothing of electronics and wouldnt even know which wires to use or what to do with them.
So i guess im asking for an idiots guide to this problem. Pics would be very helpfull.
Many thanks - Marky  :)
DaemonCollector
  • Last login:December 26, 2009, 07:02:16 pm
  • All your base are belong to us.
FractalWalk
  • Newbie
  • Last login:September 20, 2010, 06:12:37 pm
  • Life is time spent fighting entropy.
Re: Superbright led's is there a guide on wiring and what i need to do?
« Reply #2 on: February 11, 2005, 12:17:37 pm »
The Oscar tutorial is pretty advanced as it has you making your own circuit boards. Try this one for beginner's.
http://www.theledlight.com/ledcircuits.html
The main issue is that you will need to add a resistor to your LED so that it doesn't blow up. There is a calculator in that link to determine what ohm resistor to use depending on what voltage your power  supply is and what voltage your LEDs can handle (i.e. what color/type they are).
saint ganked my avatar.
namedos
  • Last login:July 16, 2025, 07:15:23 pm
« Reply #3 on: February 11, 2005, 03:38:16 pm »
Here is another site that does a good job of explaining what you need to do to set it up.  Check out the link for coin doors.
http://www.joelsgadgets.com/
GameOver
  • That's right. I'm Abe Froman.
  • Last login:February 11, 2013, 06:54:31 pm
  • Got a quarter?
    • Check out my cab!
« Reply #4 on: February 11, 2005, 06:58:34 pm »
Now, I'm not an electrician, but - my super bright LED's are 12v, just like the yellow wire from my computer's power supply.  Marky - you didn't say what the power requirement was for your lights.  If they match your power supply, I don't see the need for resistors.  I didn't need 'em, and you might not either.
FractalWalk
  • Newbie
« Reply #5 on: February 11, 2005, 07:11:41 pm »
TOK
  • The Game Always Wins
« Reply #6 on: February 12, 2005, 06:25:33 pm »
I bought some 12v LED's at an auto parts store and wired them right into the 12v on my PC power supply like Gameover said. They're 3 for $5 and come in multiple colors. I can't see messing with resistors.
Voodooray
  • Last login:July 24, 2006, 04:52:41 am
  • Load ya swine!!!!!
« Reply #7 on: February 13, 2005, 07:18:24 am »
It's a life span thing. The resister actually limits the current not the voltage. You can run them without a resister but if you use resisters they will last about ten times longer.
Voodoo Ray
88 Acid Revival, Safe!
Voodoo Ray.
ShinAce
  • Last login:January 16, 2007, 07:38:14 pm
  • Building the unbuildable since 2001
« Reply #8 on: February 13, 2005, 09:09:58 am »
The resistor limits both current and voltage. It just happens that current is more dangerous to an LED than voltage. But you need voltage to cause a current, so it's a catch 22.
An ounce of image is worth a pound of performance.
FractalWalk
  • Newbie
« Reply #9 on: February 13, 2005, 02:14:39 pm »
Run 12V thorugh 1.5v LED and the life span will be about 2 seconds.
Marky_1979
    • Personal Webspace
Thanks guys
« Reply #10 on: February 14, 2005, 04:06:53 am »
Thanks alot guy i appreciate the help, it think the power supply will be 12v and so will the leds so should be simple enough i think  :)
