Author Topic: cameltry controls  (Read 2827 times)
mlcampbe
  • Last login:December 08, 2022, 10:54:49 am
cameltry controls
« on: February 10, 2005, 06:48:21 pm »
Using the keyboard cameltry works correctly and I can navigate around just fine.
If I enable the joystick then I can't get the vertical direction working. I can only roll the ball left and right.
Since I don't have a spinner is there a way to configure the joystick to work with this game? I've tried setting the up/down/left/right using the joystick but that didn't change anything.
Thanks in advance.
GameOver
  • That's right. I'm Abe Froman.
  • Last login:February 11, 2013, 06:54:31 pm
  • Got a quarter?
    • Check out my cab!
Re: cameltry controls
« Reply #1 on: February 10, 2005, 07:00:07 pm »
Maybe I'm missing sometihing, but Cameltry only uses left/right?  I mean, that's all a spinner is....So as long as you're getting the left/right response from your joystick I'd say you're in business.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #2 on: February 10, 2005, 10:01:15 pm »
You're not controlling the BALL, you're controlling the SCREEN. Left rotates the screen one way, and RIGHT rotates it the other. Gravity makes the ball move.
NO MORE!!
JODY
  • Last login:June 08, 2025, 11:26:01 pm
  • After a long delay...the arcade is underway!
« Reply #3 on: February 10, 2005, 10:16:38 pm »
Tried it with an analog joystick and it won't work.  Works fine with my spinner.
Rocky
« Reply #4 on: February 11, 2005, 08:19:49 am »
I use either a spinner or trackball. Both work fine.
mlcampbe
« Reply #5 on: February 11, 2005, 08:33:22 am »
So why would a spinner or trackball be any different than a joystick for controlling just your left/right movement?
Especially since the keyboard works I would expect that I could get an analog joystick working as well. Perhaps not but I'd like some reasonable idea as to why.,
Rocky
« Reply #6 on: February 11, 2005, 08:44:02 am »
Spinners and Analog sticks do work differently.
ponyboy
  • Last login:February 15, 2026, 10:16:25 am
« Reply #7 on: February 11, 2005, 09:55:20 am »
Would anybody be interested in a Camel Try PCB Board???
Ponyboy
mahuti
« Reply #8 on: February 11, 2005, 10:15:52 am »
the board? Only for a paperweight.
The game is really fun. One of my favorites, but I absolutely think it requires a spinner. Without it, it just isn't that much fun.
Stingray
« Reply #9 on: February 11, 2005, 10:27:50 am »
Agreed.
-S
ponyboy
« Reply #10 on: February 11, 2005, 01:58:17 pm »
Okay, how much for a paperweight???  Hee Hee.  If I had the controller is there any interest???
Ponyboy
mlcampbe
« Reply #11 on: February 14, 2005, 10:45:47 pm »
Ok, I'm trying to decide if I need a spinner on my control panel I am designing. I know that cameltry doesn't work with the usb joystick because the usb joystick doesn't send the same keystroks that the arrow keys do. When the control panel is complete the joystick I use will be wired via an ipac and since the ipac will send up/down/left/right like the arrow keys my guess is that cameltry will work properly then.
However, since I don't have a tsilk to test with I can't say for sure. Can anyone test this out for me? If I can get cameltry working with a tsilk then for my purposes I won't need the spinner.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #12 on: February 14, 2005, 11:44:18 pm »
It'll work with a T-stick, but no better than it works with a keyboard.  You won't have the speed control that comes from using a spinner.  The screen will always rotate at the same, fixed rate, making it very hard to make the ball change directions quickly.  You'll be able to play, but never play well.
bigle
  • Last login:August 10, 2006, 02:22:54 pm
  • i may or may not be a llama
« Reply #13 on: February 14, 2005, 11:46:43 pm »
i've played the game with my t-stick plus (wired through a mini-pac).  you only use left and right.  it's playable but i imagine that it would be easier with a spinner because you could control the speed at which the maze rotates.  if you've never played it with a spinner then it probably wouldn't bother you.
edit-looks like kremmit beat me to it
who fishes with cheese?
