Author Topic: Hard Drive Horked - Again!  (Read 1934 times)
SirPeale
  • Green Mountain Man
« on: February 09, 2005, 08:06:41 pm »
I have no idea what happened, but my drive suddenly became non-bootable.
That aside, I tried using the XP CD to repair the file table.  For whatever reason, it decided to write a FAT table instead of an NTFS table, and everything is gone.
The drive was part'd to two parts, and the other 1/2 is fine.  To be safe, I've now backed up that data to another drive.
It's the other data I'm worried about.  I *can* get the data back with a recovery program, but it will take a very long time, and it'll have to write all that data to another drive.
Is there a program that will allow me to just fix what's broken so I can recover my data, or am I better off with the recovery tool?
SkateDetroit
  • Last login:April 30, 2013, 01:56:36 pm
    • SkateDetroit!
Re: Hard Drive Horked - Again!
« Reply #1 on: February 09, 2005, 10:25:17 pm »
Try sticking the drive in a working computer and running CHKDisk on it. See if that can fix any errors. It does the trick occasionally, depending on what's wrong. Hope this helps.
      ~A
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #2 on: February 10, 2005, 01:19:08 am »
I think you have to run chkdsk with the -f switch if you want it to actually do anything.
Best Kid iPad Apps
SirPeale
« Reply #3 on: February 10, 2005, 07:58:46 am »
chkdsk was the first thing I tried, and it wouldn't run.
Harry Potter
  • Smite-bait
  • Last login:May 27, 2024, 03:33:28 am
  • Sober until banned. Can post but still can't read.
« Reply #4 on: February 10, 2005, 12:40:10 pm »
Try this:
Now in a tasty new flavour.
spystyle
« Reply #5 on: February 11, 2005, 09:57:02 pm »
XP suX
Use 2000 pro, PM me if you need a copy
SirPeale
« Reply #6 on: February 12, 2005, 08:09:19 am »
Gah - I went forward and used my recovery utility (EZ Recovery).  I would have sworn that I set up that partition as NTFS.  Let it do a full scan do determine that, it took eight hours, and didn't find diddly.  So I changed some parameters, and let it do another scan, same thing.
For giggles I let it do a scan on FAT32, and it found it in ten seconds.
It took approx. two hours to fully scan the FAT32 partition, and everything was *garbage.*  There were like six recoverable files.  I don't get it.
Additionally, this is a hardware fault, why would Windows 2000 be any better?
SirPeale
« Reply #7 on: February 12, 2005, 05:16:56 pm »
Mate of mine hooked me up with a program called GetDataBack.  EZ Recovery didn't do diddly.  This is pulling *everything* out, and do I mean everything.  Wish I had this program a couple years ago, some important stuff I had back then got killed.
I'm backing up my email TONIGHT!
fredster
  • It's all good!
« Reply #8 on: February 12, 2005, 05:29:58 pm »
Did this "getdataback" utility check the files? Can you read them?
Where did you get it?  I could use something like that.
SirPeale
« Reply #9 on: February 12, 2005, 05:34:31 pm »
It checked the files, and copied them to another drive.
Quarters
  • Last login:July 08, 2010, 06:53:17 pm
  • I am not now, nor have I ever been, a llama!
    • Quarters Arcade Site
« Reply #10 on: February 12, 2005, 06:14:26 pm »
I have used r-studio lots of times with excellent results.
http://www.data-recovery-software.net/
Do not use the drive if you intend to recover data from it.
« Last Edit: February 12, 2005, 06:35:06 pm by Quarters »
97.4 percent of all statistics are full of crap.
