Author Topic: booting into mamewah win98  (Read 1201 times)
langdoguk
  • Last login:October 30, 2009, 03:45:23 pm
  • hey you Guys !
« on: February 09, 2005, 08:33:59 am »
is there a totally idiot proof (I mean as easy as it gets ) way for me to get my system to boot straight into mamewah , using win 98 ,I've more chance of winning the lottery than understanding most of the stuff that seem pretty easy.    thanks Craig
Help I'm useless !!!!
DaemonCollector
  • Last login:December 26, 2009, 07:02:16 pm
  • All your base are belong to us.
Re: booting into mamewah win98
« Reply #1 on: February 09, 2005, 08:42:16 am »
http://forum.arcadecontrols.com/index.php/topic,22414.0.html
Aboyt 10 posts down.
Just realized your on Win 98, that makes it even easier. In your system.ini file I belive, change the line that reads "SHELL=explorer.exe" to your mamewah  executable. That'll do the trick
« Last Edit: February 09, 2005, 08:47:50 am by DaemonCollector »
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #2 on: February 09, 2005, 08:46:36 am »
Hi,
I suppose you can put it in the Startup menu of win98.
right click on windows Start menu, choose "explore" , and copy and paste a shortcut to Startyp folder.
an other solution would be to modify the "run" key in the registry. but i think the first solution is easier.
Cheers,
Youki
