Author Topic: MAME blank screen but game is working - only some games  (Read 3655 times)
MoonDog
  • Last login:April 11, 2011, 03:03:28 pm
  • A mall am I!
    • My M.A.M.E Cabinet
« on: February 04, 2005, 08:30:50 pm »
Ok, I'm having a problem with a couple of my MAME games since I switched to a new computer.  I picked up a cheap AMD 1600 machine from Fry's to replace my Celeron 600.  I put XP Pro on it and lots of things work much better including some lock up problems I was having with MameWah and how my encoder would mysteriously stop working until I rebooted the pc.  I digress...
Anyway, now things work great except for a few games I have come across don't appear to have any video display, but I know the game is playing because of the sounds.  The two I have noticed are Tron and Toobin', but I have a feeling there are probably more.  Any suggestions as to what might be causing this problem?  These games were working properly before the computer swap and I copied most files from one machine to the other across a network.
Thanks.
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
Re: MAME blank screen but game is working - only some games
« Reply #1 on: February 04, 2005, 08:49:24 pm »
I imagine its a particular video resolution that mame is displaying that your new video card/drivers/monitor can not display. Try running those games but force a particular resolution and see if that works.....
fastredpacman
  • Last login:February 19, 2018, 02:12:36 am
  • What?
« Reply #2 on: February 05, 2005, 03:38:55 am »
Ive had that happen and its your hertz setting in your monitor settings in windows. Maybe you should change it from 70 to 60. That solved my mame mystery.
  • Last login:March 28, 2026, 02:54:37 pm
« Reply #3 on: February 05, 2005, 10:15:19 am »
Also.. if your video card is cheap or you have something odd running in the background, mame's d3d/dd window may be failing on you.
When they first switched over to dx7 this was a common bug, but I haven't seen it since.
MoonDog
  • A mall am I!
« Reply #4 on: February 06, 2005, 03:17:11 am »
Well no luck after changing refresh rate.  I tried all available setting (54 - 85Hz).  I'm using the on-board video card which I'm sure is about as cheap as you can get.  Maybe I'll try to find a new card and see if that makes a difference.  For now, no Toobin' for me.   :'(
