Author Topic: GBA lighting  (Read 1474 times)
muell67
GBA lighting
« on: February 02, 2005, 10:59:06 pm »
I know this doesnt have anything to do with arcade controls but I thought someone might be able to help. I recently got metal slug for my game boy advance wich I hadnt played for two years prior, Im now hooked and have been playing alot. My question is does anyone know where I can get one of the discontinued afterburner kits or how I could build my own. Ive also read about something called a halo light but its gotten mixed reviews anyone have one? Ive also considered swapping the screen for a true backlit one but im not sure if thats possible. I know I should just buy a gba sp but I dont like the feel of them.
tetsujin
  • Last login:April 10, 2007, 05:51:25 pm
  • My controls will have programmable button labels.
    • My Homepage
Re: GBA lighting
« Reply #1 on: February 03, 2005, 12:14:30 am »
Afterburners pop up on E-Bay from time to time.  That's the only source I know of.  Sometimes they go for around $50-$60 - but as with all things on E-Bay, you can get a better deal if the timing is right.The good news is that you can buy Afterburner Cases for cheap, so you don't have to deal with cutting the front half of the GBA to make room for the light guide (the hardest part of the installation IMO).
I have seen the Halo things you're talking about, I think they're junk.  Plus they have to connect externally to the link port for power, so they make a bulge in the casing.  I don't think it even has a light guide, let alone anti-reflective film like the Afterburner.
I had my afterburner GBA for a couple years and I loved it.  I didn't want to move to an SP because I preferred the larger form factor and the ability to buy batteries off-the-shelf as needed.  Then I got an afterburner for my girlfriend's GBA, but because I was rushed and overconfident from having installed the mine without mishap I totally botched hers, so I let her keep my GBA and got an SP for myself.  It's really quite nice and I've grown quite attached to it.  Now and then I miss the full-size shoulder buttons (playing Street Fighter, in particular) but it's good stuff.
I don't know if it'd be possible to install the SP screen onto a regular GBA...  in principle, probably, it's the same size screen and all...  but those fragile laminated ribbon cables absolutely suck.  I wouldn't want to try it.
If you get an Afterburner, just be sure to take your time, keep your work area clean, and familiarize yourself thoroughly with the directions.  It's not a hard installation at all.
---GEC
