Author Topic: z26 GUI corruption  (Read 1322 times)
FunkyBoss
  • Last login:January 30, 2005, 10:05:09 pm
z26 GUI corruption
« on: January 30, 2005, 11:06:26 am »
I'm seeing an issue with the z26 emulator where certain games display a series of black lines across the left side of the screen.  Some of the games are Mrs. Pac-Man, Pooyan and Raft Rider.  I tried these in Stella as well and I only see the corruption in Pooyan.  The other 2 games play fine without the black lines.
Is anyone else seeing this too?  Is there some setting I can change to correct it?  I am using an ATI Radeon 9600 video card and have tried all of z26's video modes, and all that work with my monito exibit the same behavior.  The one I have been using on my cabinet is -v7 which is 640x480.
jcrouse
    • CPViewer
Re: z26 GUI corruption
« Reply #1 on: January 30, 2005, 01:47:05 pm »
Are you using a z26.cli file? Have you tried different video settings and/or the default refresh rate flag in it?
John
ryckster
  • Last login:February 05, 2005, 03:30:47 am
    • Dat Maker 2.0
« Reply #2 on: January 30, 2005, 02:05:56 pm »
I am no expert, but I think the black lines are normal. The atari had no video buffer so everything had to be drawn realtime on the screen. Programmers used a few clock cycles of this drawing time to make calculations, which resulted in the black lines you see in many a2600 games.
DaemonCollector
  • Last login:December 26, 2009, 07:02:16 pm
  • All your base are belong to us.
« Reply #3 on: January 30, 2005, 10:00:52 pm »
Yup, many games will have black lines along the edge of the screen, very normal in a lot of 2600 games :)
