Author Topic: 25-30 watt tube enough for marquee?  (Read 1456 times)
megashock5
  • Last login:May 19, 2015, 06:51:16 am
« on: January 26, 2005, 11:28:24 am »
I searched the forum and saw some posts, but no concrete info on flourescent tube wattage for behind the marquee.
I just picked up a GE brightstick33 or something like that because it had a plug (instead of direct-wire) and the fixture is 25" wide, 1" smaller than the inside dimension of the cab.
From what I can gather, it supposed to be about 33 watts of light, but it uses 25. Most of the bulbs I've seen small enough to fit are about 20 watts.
I haven't opened it yet, so I was wondering if you guys thought it would be bright enough.
thanks!
quarterback
Re: 25-30 watt tube enough for marquee?
« Reply #1 on: January 26, 2005, 11:31:51 am »
I think the stock flo in my cab is only 15w
-- Chad Tower
Trimoor
  • Last login:November 18, 2006, 09:01:46 pm
  • I like shooting out of helicopters.
    • Trimoor
« Reply #2 on: January 26, 2005, 11:35:24 am »
If anything it would be too bright, but you can always put paper between to diffuse it.
« Reply #3 on: January 26, 2005, 12:09:39 pm »
Yes 20W should be more than enough.
Ken Layton
  • Guru
  • Technician
« Reply #4 on: January 26, 2005, 12:22:21 pm »
JAMMA and A.M.O.A. compliant cabinets are standardized on using F15T8 (15 watt, 18" long) fluorescent lights and have been since 1990.
megashock5
« Reply #5 on: January 26, 2005, 12:46:41 pm »
Cool, thanks guys!
If it's a little bright I'll try to diffuse it.
