Author Topic: mamewah list generation errors  (Read 2084 times)
quadmasta
  • Last login:May 18, 2022, 03:23:00 pm
    • Approximate Arcades
« on: January 23, 2005, 08:45:45 pm »
I'm running Mamewah 1.52 and Mame .90 and I'm having issues with list generation.  All of the paths are correct as far as I can tell and the ini files point to the right spots.  When I try to create a MAME "all games" list it acts like it's going through all of the files like it should but it doesn't return any games on the list.  This is driving me crazy!
Anybody have any ideas?
Brian
Re: mamewah list generation errors
« Reply #1 on: January 24, 2005, 12:12:28 pm »
Make sure you have the relevent version of xml2info.exe in your mame folder, assuming you are using a listxml list_generation_method.
quadmasta
« Reply #2 on: January 24, 2005, 12:36:27 pm »
I'm using MAME.90 with the newest version of xml2info.exe and trying verifysets_vs_listxml generation method.
will this ROM_path work?
rom_path                                  e:\mame\roms;e:\mame\roms\Acclaim PSX;e:\mame\roms\Atari PSX;e:\mame\roms\Atlus PSX;e:\mame\roms\Baby Phoenix GV system;e:\mame\roms\Cassette System;e:\mame\roms\CVS Bios;e:\mame\roms\Hyper NeoGeo64 Bios;e:\mame\roms\Max-A-Flex;e:\mame\roms\Mega Play BIOS;e:\mame\roms\Mega-Tech BIOS;e:\mame\roms\Multi Amenity Cassette System BIOS;e:\mame\roms\Neo-Geo;e:\mame\roms\Nintendo Super System BIOS;e:\mame\roms\PGM (Polygame Master) System BIOS;e:\mame\roms\PlayChoice-10 BIOS;e:\mame\roms\PS Arcade 95;e:\mame\roms\ST-V BIOS;e:\mame\roms\Super Kaneko Nova System BIOS;e:\mame\roms\System GX;e:\mame\roms\Taito;e:\mame\roms\Standard;e:\mame\roms\Taito FX1;e:\mame\roms\TPS;e:\mame\roms\ZN1;e:\mame\roms\ZN2
« Last Edit: January 24, 2005, 12:49:49 pm by quadmasta »
« Reply #3 on: January 24, 2005, 03:03:23 pm »
No, you must specify one path only, ie e:\mame\roms.  Then use list_generation_method verifysets_vs_listxml - that should do what you want.
quadmasta
« Reply #4 on: January 24, 2005, 04:29:24 pm »
here's mamewah's mame.ini
### mame.ini (mamewah v1.60) ###
emulator_title                            M.A.M.E.
### List Generation Settings ###
rom_extension                             zip
dat_file
nms_file
catver_ini_file
### Execution Settings ###
emulator_executable                       e:\mame\mame.exe
commandline_format                        [name]{autodosbox}{nosafelaunch}
alt_commandline_format_1                  [name]{autodosbox}{nosafelaunch}
alt_commandline_format_2                  [name]{autodosbox}{nosafelaunch}
game_specific_config_path
### Artwork Locations ###
artwork_1_image_path                      e:\mame\snap
artwork_2_image_path
artwork_3_image_path
artwork_4_image_path
artwork_5_image_path
artwork_6_image_path
artwork_7_image_path
artwork_8_image_path
artwork_9_image_path
artwork_10_image_path
movie_preview_path
movie_artwork_no                          1
### Screen-Saver Settings ###
enable_music_in_screensaver               1
saver_type                                slideshow
movie_path
movie_fullscreen                          1
quit_delay                                30
wrapper_executable
wrapper_commandline_format                [name]{nodosbox}{nosafelaunch}
scr_file
### External Application Settings ###
ipc_file_or_path
app_1_executable
app_1_commandline_format
app_2_executable
app_2_commandline_format
app_3_executable
app_3_commandline_format
auto_launch_apps
### Additional Settings ###
music_path
lcd_display_file_path
lcd_fe_text
### Settings used by MAMEWAH ###
current_list                              0
Here's mamewah.ini
### mamewah.ini (mamewah v1.60) ###
### (Global) Screen-Saver Options ###
delay                       300
slide_duration              3
### Audio Options ###
enable_sounds               1
sound_volume                100
music_path
enable_music                1
music_volume                100
### Movie Options ###
intro_movie_file
exit_movie_file
keep_movie_preview_aspect   game_aspect
delay_before_movie_preview  2
music_movie_mix             mute_movies
movie_volume                100
### Misc Options ###
layout                      Classic 640x480
ctrlr
wrap_list                   0
remember_current_game       1
keep_image_aspect           1
refresh_images              0
correct_orientations        horizontal
safe_mode                   0
show_cursor                 0
keyboard_led_states         -,-,-
winipac_file
mamewah_ipc_file
lcd_com_port                1
lcd_settings
exit_action                 choice
app_to_run_on_exit
current_emulator            mame
locked                      0
last_ipc
here's mame's mame.ini
### mame.ini ###
### Frontend Related ###
clones                  1
### Windows path and directory options ###
rompath                 roms
samplepath              samples
# inipath               <NULL> (not set)
cfg_directory           cfg
nvram_directory         nvram
memcard_directory       memcard
input_directory         inp
hiscore_directory       hi
state_directory         sta
artwork_directory       artwork
snapshot_directory      snap
diff_directory          diff
ctrlr_directory         ctrlr
cheat_file              cheat.dat
history_file            history.dat
mameinfo_file           mameinfo.dat
### Windows video options ###
autoframeskip           1
frameskip               0
waitvsync               0
triplebuffer            0
window                  0
ddraw                   1
direct3d                0
hwstretch               1
cleanstretch            auto
resolution              1024x768x32
zoom                    2
refresh                 0
scanlines               0
switchres               1
switchbpp               1
maximize                1
keepaspect              1
matchrefresh            0
syncrefresh             0
throttle                1
full_screen_brightness   0.000000
frames_to_run           0
effect                  none
screen_aspect           4:3
sleep                   1
rdtsc                   0
high_priority           0
### Windows Direct3D 2D video options ###
d3dtexmanage            1
d3dfilter               1
d3dfeedback             0
d3dscan                 100
d3deffectrotate         1
d3dprescale             auto
d3deffect               none
# d3dcustom             <NULL> (not set)
# d3dexpert             <NULL> (not set)
### Windows sound options ###
audio_latency           1
### Input device options ###
mouse                   0
joystick                0
lightgun                0
dual_lightgun           0
offscreen_reload        0
steadykey               0
keyboard_leds           1
led_mode                ps/2
a2d_deadzone            0.300000
# ctrlr                 <NULL> (not set)
### Mame CORE video options ###
norotate                0
ror                     0
rol                     0
autoror                 0
autorol                 0
flipx                   0
flipy                   0
debug_resolution        auto
gamma                   1.000000
brightness              1.000000
pause_brightness        0.650000
### Mame CORE vector game options ###
antialias               1
translucency            1
beam                    1.000000
flicker                 0.000000
intensity               1.500000
### Mame CORE sound options ###
samplerate              44100
samples                 1
resamplefilter          1
sound                   1
volume                  0
### Mame CORE misc options ###
artwork                 1
use_backdrops           1
use_overlays            1
use_bezels              1
artwork_crop            0
artwork_resolution      0
cheat                   0
debug                   0
# playback              <NULL> (not set)
# record                <NULL> (not set)
log                     0
maxlogsize              10000
oslog                   0
skip_disclaimer         1
skip_gameinfo           1
crconly                 0
bios                    default
# state                 <NULL> (not set)
### Configuration options ###
readconfig              1
verbose                 0
I have no idea why it's not working
« Reply #5 on: January 26, 2005, 05:33:31 am »
Not sure, but you could try explicitly stating your rompath in (mame's) mame.ini:
rompath                 e:\mame\roms
quadmasta
« Reply #6 on: January 26, 2005, 12:19:23 pm »
I got it figured out.  I had to remove the spaces from the folder names and remove the single quotes from the rom_path in mame's mame.ini  For whatever reason, mamewah was kicking me back to the list menu before mame quit running info2xml and showing an empty list but eventually the list populated itself.
