Author Topic: What does it mean that I monitor needs Isolation?  (Read 1416 times)
TheRCGuy
  • Last login:March 20, 2005, 07:24:45 pm
« on: January 22, 2005, 01:24:48 pm »
I see that there are Non-Isolation monitors and then there are some that needs Isolation. What does this mean?
shadowdrak
  • Last login:November 20, 2005, 04:59:54 pm
  • I'm still a llama!
Re: What does it mean that I monitor needs Isolation?
« Reply #1 on: January 22, 2005, 04:58:01 pm »
that is in the FAQ i believe... the top post.  Some monitors have what is called a "hot-chasis" IIRC if you plug them in directly they will break.  That is what the transformer is for.  If you have a specific monitor model, someone here should know if it needs one.
TheRCGuy
« Reply #2 on: January 22, 2005, 06:08:35 pm »
I could not find it in the FAQ ( that area seems like a mess to find anything ) I have a working cab that needs a 19"CGA monitor in the cabinet it has the plug for the RGB signal for the monitor and it has a 2 prong plug that also goes to the monitor ( I guess this is a power wire, I have no clue)
Do this give you any info that would be helpful in telling me what I need Isolation or non-isolation monitor?
Thanks for any help!
SirPeale
  • Green Mountain Man
SirPeale
TheRCGuy
« Reply #5 on: January 22, 2005, 07:16:52 pm »
Thanks MAN!!
