Author Topic: X-arcade PCB connectors  (Read 1097 times)
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
« on: January 20, 2005, 06:38:10 pm »
I discovered on my single player X-arcade that there are still 13 active inputs (which are used on the two player model).  The inputs are accessed through 5 pin nylon PCB connectors.  I have been unable to find matching connectors for the PCB headers.  Has anyone else used the X-arcade encoder and found connectors that work?
Pacific Ripper
  • Last login:May 14, 2008, 12:14:30 pm
  • Tearing it up like a rag doll.
Re: X-arcade PCB connectors
« Reply #1 on: January 22, 2005, 12:32:49 pm »
You can go to Fry's Electronics or some other like it like MarVac and ask the local clerk for the connectors. I forgot what the part number was, but it's there.
logik
  • Last login:July 02, 2012, 03:10:23 pm
« Reply #2 on: January 22, 2005, 03:48:03 pm »
I was looking for those connectors everywhere. I could not find anything. Frys by me only has 4 and 6 pin connectors. I ordered some from a few on-line retailers, but none were the right size. I asked x-arcade what they were, but they would not say. You could try emailing them, see if they like you better :) If you do find out, post up.
