Author Topic: Wavy picture on WG 7000?  (Read 1487 times)
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« on: January 19, 2005, 10:46:08 pm »
I have 7000 series monitor and the picture is wavy.  The best I can describe it is that it looks like a reflection on top of water that is rippling.  The person I bought it from said it was called a 60Hz hum and that it could be easily fixed with a cap kit.  I replaced the caps and the problem is still there.
In some games it is barely there but in others it is much worse.  One thing I thought I would mention is the the power supply is located very close to the monitor.  I didn't know if this could create the problem.
I have another question on this monitor and it has to do with the horizontal width coil.  Exactly what do I need to use to adjust this?
Thanks in advance!
Ken Layton
  • Guru
  • Technician
Re: Wavy picture on WG 7000?
« Reply #1 on: January 20, 2005, 02:07:49 am »
Your 'wave' problem may be what Randy Fromm's site says is 'doing the hula' symptom. Generally a bad voltage regulator IC or main filter cap cause this.
To adjust the width coil: www.dameon.net/BBBB/wc.html
