Author Topic: Can't complete configuration wizard in cpviewer  (Read 1227 times)
rerstad
  • Last login:December 11, 2006, 01:25:57 pm
« on: January 15, 2005, 01:18:04 pm »
I think I've got cpviewer about up and running, but I can't complete the configuration wizard because I really can't run my monitor above 480x640.  I'm running it vertically on my cocktail and it cuts off the final buttons on the right side. I can barely see the "back" button on the screen with the previews.  I can't reach any button to the right of the screen. I tried running the wizard horizontally on my monitor with no  luck either.  Can I set things up manually?
jcrouse
    • CPViewer
Re: Can't complete configuration wizard in cpviewer
« Reply #1 on: January 15, 2005, 05:45:47 pm »
Are you able to TAB to it and use the Enter key?
John
rerstad
« Reply #2 on: January 15, 2005, 05:53:46 pm »
I tried it and was able to tab to something I couldn't see.  When I hit enter it said configuration was complete.  Right now it won't load in Mamewah using the text from your sample ini.  Checked that the path's right.  I assume to launch from Mamewah, I press 2 and got to launch external app.  When I do, it won't load.  Guess I'll try to figure this one out. . . .
