Author Topic: mame with medium resolution monitor  (Read 3575 times)
vincentc77
  • Last login:May 11, 2020, 08:14:22 pm
« on: January 12, 2005, 08:25:19 am »
What mame version and vga card are recommended to run mame on a medium resolution monitor from NFL Blitz.  I believe the cab was originaly a Sega VF.  Could the monitor be modded to a 15k?
« Last Edit: January 12, 2005, 09:32:45 am by vincentc77 »
hiperco
  • Last login:January 14, 2014, 08:15:13 pm
  • Mame is Cool
Re: mame with medium resolution monitor
« Reply #1 on: January 12, 2005, 11:32:59 am »
AFAIK, only option is Advancemame.  There are many compatible video cards listed.  It is possible to do this in windows using Powerstrip, but I've had mixed results with Powerstrip so far.
I'm setting up a standard res monitor using DOS Advancemame and a Nvidia Riva TNT/2, which seems to be working pretty well so far.
Now if only I could get my sound card to work in DOS  ::)
I'd be glad to point you in the right direction if you decide to go this route.   My initial advice is that you should be comfortable working in DOS.
« Last Edit: January 12, 2005, 11:42:40 am by hiperco »
b3atmania
  • Last login:November 25, 2005, 09:48:57 am
« Reply #2 on: January 12, 2005, 02:24:56 pm »
What mame version and vga card are recommended to run mame on a medium resolution monitor from NFL Blitz.  I believe the cab was originaly a Sega VF.  Could the monitor be modded to a 15k?  Any help would be greatly appreciated.
Thanks,
Charlie
Many original Sega VF cabs had Hantarex dual sync monitors. Try to find a model id on the monitor chassis somewhere and we can tell you if it can do 15kHz.
vincentc77
« Reply #3 on: January 18, 2005, 09:25:57 am »
Ok,
I got the Trident Blade T64 installed and I'm booting into DOS.
Here is what I found on the main board...
025a1452-001
85x0414-001
p767
three jumpers...
p702 h sync
p704 norm
p300 norm comp
I have pictures, but I don't know how to post them...
« Last Edit: January 18, 2005, 09:40:07 am by vincentc77 »
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
« Reply #4 on: January 18, 2005, 09:33:42 am »
on the bottom of the post click additional options, you can upload there
"Owens is the ringleader in the ass hat circus"  D K
hiperco
  • Mame is Cool
« Reply #5 on: January 19, 2005, 07:12:06 pm »
Try the i and k keys (k first I suggest, seems like a horizonatal problem) (and also shift i and k)
This page shows what the screen looks like when you get locked in:  http://easymamecab.mameworld.net/html/monito10.htm
hiperco
  • Mame is Cool
« Reply #6 on: January 19, 2005, 11:17:51 pm »
And this page is very helpful as well:
http://easymamecab.mameworld.net/html/advadv.htm
You might need to add the special lines for the trident card (if you haven't already)
vincentc77
« Reply #7 on: March 09, 2005, 02:20:59 pm »
What special lines are needed in the rc file for the trident card?
Thanks,
Charlie
rockmes
  • Last login:June 05, 2016, 09:41:38 am
  • Don't you love it?
« Reply #8 on: March 09, 2005, 02:36:59 pm »
device_video vbeline vgaline
device_video_pclock 5-90
device_video_hclock 15.75
device_video_vclock 48-60
l also got the trident t64 ,and also use the tsr drivers if using windows98 make everything look great upon booting into windows.
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #9 on: March 09, 2005, 10:42:58 pm »
Shouldn't the device_video_hclock be 25?
He did say medium resolution.
Later,
dabone
