Author Topic: GENSFE Full Screen issue  (Read 865 times)
nussmier
  • Last login:November 06, 2018, 08:03:23 pm
« on: January 11, 2005, 09:12:25 am »
When I try to run GENSFE in full screen mode it is actually bigger then my screen.  Im sure this is a resolution issue but have not been able to fix it.  I was hoping someone else came across this and knows what the issue is.  Thanks
jcrouse
    • CPViewer
Re: GENSFE Full Screen issue
« Reply #1 on: January 11, 2005, 12:11:48 pm »
How much bigger? With some monitors, the first time a resolution is used you need to use the monitor adjustments to resize and center the image. After that, most monitors will remember the position and size for that particular resolution.
John
nussmier
« Reply #2 on: January 11, 2005, 05:46:17 pm »
Well it fits fine horizontally but vertically I am missing about 30% of the screen.  I dont think it is a vertical size issue but I will give it a try when I get a chance.
the3eyedblindman
  • Last login:November 17, 2006, 03:00:06 pm
  • Soon: 4 Player Mame and Scratch Built Moonwalker.
« Reply #3 on: January 12, 2005, 09:42:22 pm »
how do you get gens to load into full scree, i have to manually press alt+enter everytime to fullscreen, mame and virtuanes does not do this..  ???
Coming soon: 4 player mame cab and Scratch built Moonwalker....Hall of Fame, here I come!
