Author Topic: NFL BLITZ - Impossible to Configure!  (Read 3373 times)
bsoder52
  • Last login:June 24, 2025, 11:29:40 pm
« on: January 10, 2005, 08:41:21 pm »
I swear that NFL Blitz PC is just impossible to configure with an IPAC.
Nothing works!
Any help is much appreciated.
bsoder52
darkmavis
  • Last login:April 25, 2006, 04:33:37 am
Re: NFL BLITZ - Impossible to Configure!
« Reply #1 on: January 10, 2005, 09:05:44 pm »
it uses  weird joysticks joysticks dont it?
from www.klov.com
Manufacturer: Midway
Year: 1997
Class: Wide Release
Genre: Sports
Type: Videogame
Monitor:
    * Orientation: Horizontal
    * Type: Raster: Medium Resolution
    * CRT: Color
Conversion Class: JAMMA+
Number of Simultaneous Players: 2
Maximum number of Players: 2
Gameplay: Either
Control Panel Layout: Multiple Player
Controls:
    * Joystick: 49-position optical
    * Buttons: 3
Sound: Amplified Stereo (two chann
RacerX
  • Last login:April 25, 2024, 04:53:33 pm
  • Longtime member, sometime poster.
« Reply #2 on: January 10, 2005, 09:12:36 pm »
Blitz for the PC doesn't need a 49 way, though, obviously.
I have Blitz configured just fine.  You should be able to configure it with a IPAC.  Just remap the buttons in Blitz to the same ones that you have your IPAC mapped to.
What specifically is the problem?
darkmavis
« Reply #3 on: January 10, 2005, 09:45:23 pm »
sorry, thought he meant the chd on the pc, miunderstood.. ignore me :)
coachcarstens
  • Last login:November 19, 2007, 10:42:59 pm
« Reply #4 on: January 10, 2005, 10:29:24 pm »
I have blitz 2000 pc and i'm having the same problem.  On my cp wich uses a keyboard hack, joystick one works which uses up/down/left/right but no other button works.  On the second keyboard every button works.  when i try to remap they keys nothing happens.  I use win xp, and have tried running in win 98 mode also.  Any ideas?
bsoder52
« Reply #5 on: January 10, 2005, 11:07:35 pm »
I've tried to remap all the controls though my IPAC.
Here is the detailed issue at hand:
When I have the game up and running most of the controls are numeric.
Only the keypad on the right side of my keyboard works, if I use any numbers ontop of the keyboard the game doesn't respond.
So no problem right, just use the right hand numbers to remap the keys,.....wrong......
When I map number 6 for a pass, it inputs like "END" in the Ipac reconfiguration application screen.
Any suggestions?????//
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #6 on: January 11, 2005, 02:28:17 pm »
[snip]
Make sure the keyboard has num lock on.  But I'd think number 1 would get END, and number 6 would be left arrow if this was the problem...
from www.klov.com [snip]
Well, besides klov is often wrong and should not be taken as The Truth....
The original arcade could be played with either 49-way OR 8-way, and there's a dipswtich to switch between the two.  Mame has the dipswitch, but only the 8-way one works.
Robin
Knowledge is Power
bsoder52
« Reply #7 on: January 11, 2005, 02:31:11 pm »
I'll try the numbers lock tonight and see if that makes and difference.
Pretty sure I try toggling it.
Gunstar Hero
  • Last login:September 28, 2014, 01:51:17 am
  • Back in action!
« Reply #8 on: January 11, 2005, 03:47:30 pm »
I got the in game button config to work, but it was a PAIN... took like 20 minutes.  :P
You have to do alot of setting controls, finding the conflicts, then eliminating the conflicts.
Gunstar Hero
  • Back in action!
« Reply #9 on: January 11, 2005, 03:48:37 pm »
I don't use the default IPAC settings though... I changed mine to remove buttons like enter, control and alt.
