Author Topic: Need help picking MAME FE for slow PC  (Read 2419 times)
Mario
  • Last login:March 29, 2021, 08:55:12 pm
  • Mmmmm.....arcades!
    • Mario's Arcade Page
« on: January 10, 2005, 01:17:24 pm »
I need help choosing a frontend (FE) for a slow PC (I think it's a P1 at ~300MHz with 32MB memory). I planned to use GameLauncher, but it runs much too slow (it's constantly trashing the hard drive, even when paging thru the game list). I tried MameMenu and MameWah, but those didn't work out. Rather than try to install, configure, and then run many of the various FEs out there, I thought I'd ask for others' opinions.
Minimally, the FE must:
- run fast
- run in DOS (a DOS rip from Win 98SE)
- support reconfigurable keys (I'm using a keyboard hack)
Ideally, I'd like it to show screenshots while browsing the game list. That's about it. It doesn't have to be fancy.
Thanks.
Mario
Re: Need help picking MAME FE for slow PC
« Reply #1 on: January 10, 2005, 01:49:15 pm »
I'd normally recommend GameLauncher....were you running it from pure DOS or DOS mode in Win98?  Make sure you do the former...
Alternatively, try ArcadeOS (again run in pure DOS).
jcrouse
    • CPViewer
« Reply #2 on: January 10, 2005, 03:16:37 pm »
I used this one for over a year and really liked it and he still seemd to answer questions via email, although that was over a year ago.
http://edsfamily.com/ed/mamemenu/
John
Mario
« Reply #3 on: January 10, 2005, 06:20:12 pm »
Mario
« Reply #4 on: January 10, 2005, 06:21:19 pm »
John
Thanks, but as I stated in my original post, I tried MameMenu and it didn't work out. Maybe I'll give it another go if there are no other suggestions.
Mario
Chris
    • Chris's MAME Cabinet
« Reply #5 on: January 10, 2005, 06:37:51 pm »
I'll bet the problem is in your PC configuration; you're probably not loading Smartdrv.  What does your AUTOEXEC.BAT and CONFIG.SYS look like?
--Chris
--Chris
Mario
« Reply #6 on: January 10, 2005, 09:59:01 pm »
Mario
« Reply #7 on: January 11, 2005, 01:37:19 pm »
