Author Topic: "standard" and "medium" compatability questions? update:*I got pics*  (Read 3106 times)
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
Hey guys, im not sure what kind of monitor i have, i tried looking for a model number to no avail but i will see if i can get some pics tonight.
the cab is a conversion of what seems to be either a TMNT or a Xmen cab, which both use standard. it has gauntlet dark legacy in it which needs a medium res monitor according to KLOV.
« Last Edit: January 12, 2005, 05:56:31 pm by Sephroth57 »
"Owens is the ringleader in the ass hat circus"  D K
darkmavis
  • Last login:April 25, 2006, 04:33:37 am
Re: "standard" and "medium" compatability questions?
« Reply #1 on: January 10, 2005, 10:25:57 am »
as far as i understand it, if its a 25khz,  it will not run 15khz(std) games if you csn get the model no the guys will be able to tell u what it is, they helped me loads :D
Ken Layton
  • Guru
  • Technician
« Reply #2 on: January 10, 2005, 10:37:04 am »
Remember that there are errors in the KLOV listings.
Sephroth57
  • Poo Monkey
    • Check it out!!!
Re: "standard" and "medium" compatability questions? update:*I got pics*
« Reply #3 on: January 12, 2005, 05:59:12 pm »
hopefully these are good enough for you guys to figure something out, the cab is in the back corner its hard for me to get a good shot and i cant really move it right now theres stuff all around it.
i got these numbers if they mean anything..
off of the main monitor board, on a metal piece sticking up (you can see it int he pic)
25X3219 - 001 C
off the tube itself this was kind if imprinted on it "V 100"
and on the tube there is a sticker that says "Pix Tube Serial No. 313688"
this thing looks old as hell, i doubt this is a medium res monitor.. but hopefully thats the case
Ken Layton
  • Guru
  • Technician
« Reply #4 on: January 12, 2005, 06:04:47 pm »
Wells-Gardner 25k7191 standard resolution. Visit www.jstookey.com/arcade/WG_25k7191/ for more information. This monitor uses the standard k7000 cap kit.
Sephroth57
  • Poo Monkey
    • Check it out!!!
« Reply #5 on: January 12, 2005, 06:07:33 pm »
so i was right, the graphics ARE fuzzy compared to another machine i saw in the arcade. whoever converted this put Gauntlet Dark Legacy a MEDIUM res game on a standard monitor.
thanks for your help Ken
hiperco
  • Last login:January 14, 2014, 08:15:13 pm
  • Mame is Cool
« Reply #6 on: January 12, 2005, 09:09:18 pm »
Not possible, it wouldn't work, unless that game can be set to run at 15kHz?
« Last Edit: January 12, 2005, 09:11:41 pm by hiperco »
Rocky
« Reply #7 on: January 12, 2005, 09:54:55 pm »
I think the board is selectable for standard or medium resolution.
