Author Topic: Converting NES pads to USB?  (Read 5134 times)
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
« on: January 10, 2005, 12:06:10 am »
I am thinking about buying some NES/SNES USB kits from RetroZone but getting 4 of them would cost quite a bit. So now I am trying to come up with an alternative, maybe a keyboard hack. The problem is that I prefer not to modify the pads, I want to mount everything in a box and plug in normal pads. That means that I would need some way of converting the data back to switch presses.
Is there an easy way to decode a TC4021BP serial chip? Here is the data sheet (pdf)
I can't say I know anything about serial, so I'm not even sure that there is such thing as a decoder chip.
« Last Edit: January 10, 2005, 12:20:20 pm by Peale »
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
Samstag
  • Last login:December 16, 2016, 01:41:19 am
  • That's not a llama!
Re: Converting NES pads to USB?
« Reply #1 on: January 10, 2005, 01:08:06 am »
How to interface one or two stock NES controllers:
http://www.geocities.com/hybrid_x/misc/ninja.html
My hacked NES to USB (keyboard hack) project:
http://forum.arcadecontrols.com/index.php/topic,29529.0.html
So yes, you can decode the stock signals but you're still going to need a decent interface to the PC.
Tahnok
    • Table Arcades
« Reply #2 on: January 10, 2005, 01:31:18 am »
So yes, you can decode the stock signals but you're still going to need a decent interface to the PC.  Using the PC joystick port is going to put limits on what you can do with them.  Otherwise you're still going to need a keyboard hack or encoder to interface the discreet outputs of that circuit to your PC.
Wow! Does that actually decode the signals back to switches? What do you mean 'a decent interface to the PC', can you hook it up to a keyboard encoder/hack? If it is indeed what I think it is, you have just made my day! Where did this article come from?
*goes to read in more detail*
spiffyshoes
  • Last login:September 20, 2015, 01:24:46 pm
« Reply #3 on: January 10, 2005, 01:41:30 pm »
If you ask the guys from retrozone will give you a conversion kit for a NES 4-Score Multi Tap for $17 plus shipping so $23 all together.  And if you don't have a 4-Score Multi Tap you can buy one off of ebay for $10-15 including shipping.  Which would essentially act as a USB converter that would allow you to hook up 4 NES pads whithout having to mess up any of the NES pads themselves.  And is cheaper than buying 4 Single Pad Kits.
Samstag
« Reply #4 on: January 11, 2005, 04:17:31 am »
M3talhead
  • Last login:October 09, 2020, 07:35:12 pm
  • Dont let Donkey Kong use your toilet.......
« Reply #5 on: January 11, 2005, 09:51:22 am »
Could this NES/USB conversion be applied towards a NES Zapper lightgun????
Signature tags are dumb.
Samstag
« Reply #6 on: January 12, 2005, 01:02:30 am »
I found an old thread here:
http://arcadecontrols.com/wwwboard/messages/40154.html
It looks like it can be done with a little extra interfacing, but unfortunately the schematic that was posted is a broken link now.  I think it would basically be a transistor or optocoupler switch circuit that turns the low-level light sensor from the gun into a switch-level output.
moonpatrol 4 lyfe
  • Last login:May 08, 2011, 04:32:18 pm
« Reply #7 on: January 14, 2005, 09:33:04 am »
I know an interface that will let you have 5 controllers at once per parallel port (works with SNES and NES)
let me know if you're interested
-Bill
logik
  • Last login:July 02, 2012, 03:10:23 pm
« Reply #8 on: January 15, 2005, 10:37:53 am »
-Bill
I am, post it up!
