Author Topic: SOLVED Anyone have a Mame 0.55 SlikStik classic default.cfg file I could have?  (Read 1440 times)
jimj
  • Last login:August 27, 2024, 06:39:31 pm
I'm finally going to try out PaigeOliver's advice I revert back to Mame 0.55 to see what kind of speed improvement I can get.  The problem is that I'm using a SlikStik classic and Mame 0.55 doesn't look like it has support for ctrlr files yet.  From what I can tell you can manually configure all the default key settings from within Mame to create a default.cfg file that will work with the SlikStik Classic.  Is this correct?  If so, I does anyone have a default.cfg file already set up to work with the SlikStik Classic?  I'd rather not re-invent the wheel if I don't have to.  :)
TIA,
Jim
« Last Edit: January 15, 2005, 02:15:02 pm by jimj »
jimj
Re: Anyone have a Mame 0.55 SlikStik classic default.cfg file I could have?
« Reply #1 on: January 15, 2005, 02:14:31 pm »
I created a default.cfg that works with Mame 0.55.  Simply put the attached file in mame\cfg, remove the .txt extension (i.e. rename it to "default.cfg") and your SlikStik Classic CP should work.
