Author Topic: Need help removing my balls.... rubber grommet that is.  (Read 2466 times)
Wyluli
  • Last login:February 11, 2013, 06:38:03 pm
  • Stupid Stupid Rat Creatures!
« on: January 08, 2005, 04:29:19 pm »
Ha, thought that would get your attention.
« Last Edit: January 08, 2005, 05:42:18 pm by Wyluli »
Goz
  • KOTA
Re: Need help removing my balls.... rubber grommet that is.
« Reply #1 on: January 08, 2005, 06:07:19 pm »
When I read the title, my first reaction was to hook you up with my sister in-law.
Second reaction was that I couldn't do that to anyone with a clear conscience (sp)
Sorry can help with the actual question.
-Goz
Trimoor
  • Last login:November 18, 2006, 09:01:46 pm
  • I like shooting out of helicopters.
    • Trimoor
« Reply #2 on: January 08, 2005, 06:19:38 pm »
I had the same problem, but fortunately my balls were not yet mounted. ;D
Use lots of penetrating oil.  Let it soak in.  This is probably the only thing you can do,
I had to put mine in the freezer for a while, put them in a vice and whack them with a hammer.
Obviously this would be rather difficult while they are still attached to the control panel.
Wyluli
« Reply #3 on: January 08, 2005, 06:32:36 pm »
-Goz
Wheew, remind me not to get on your bad side man!
Searcher7
  • Last login:June 21, 2009, 10:45:22 pm
« Reply #4 on: January 08, 2005, 10:59:08 pm »
Soak it in Coke.(Let it sit overnight if necessary).
Darren
Hiub1
  • Last login:June 05, 2011, 11:43:25 am
  • www.sleepyjack.com
« Reply #5 on: January 09, 2005, 12:47:22 am »
El WD40 work?
krick
  • Gotta have blue hair.
« Reply #6 on: January 09, 2005, 12:49:09 am »
??? COKE ???
n.  Cocaine.
n.  A trademark used for a soft drink.
n.  The solid residue of impure carbon obtained from bituminous coal and other carbonaceous materials after removal of volatile material by destructive distillation. It is used as a fuel and in making steel.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #7 on: January 09, 2005, 03:47:17 pm »
First, I'll assume you already removed the E-clip right? (heh ok dumb question, but you never know round here...)
Next, try firmly gripping the ball and TWIST.
NO MORE!!
Wyluli
« Reply #8 on: January 09, 2005, 03:50:38 pm »
Update:
I e-mailed bob robert to see if he had replacement grommets so I could just rip the old one off and order a replacement.  Here was his response:
"No.... no one has had those repro'd & it usually ruins the whole stick when you try to remove them. They rust solid to the shaft & even a torch won't save the shaft :-("
Looks like I will have to buy new joysticks.  Anyone know where I can get a red ball top and blue ball top old leaf style joystick for my cab?
Rocky
« Reply #9 on: January 09, 2005, 05:10:32 pm »
Wyluli,
It is possible to get some of them loose.
Trimoor
    • Trimoor
« Reply #10 on: January 09, 2005, 05:37:30 pm »
If you decide to cut them off, cut the shaft, not the grommet.  It could be used for another stick, or sold.
RayB
  • There's my post
    • RayB.com
« Reply #11 on: January 09, 2005, 05:59:34 pm »
Those sticks pop up on ebay now and then... even blue ones.
NO MORE!!
