Author Topic: Best way to switch between video inputs? (to switch between PC/MAME and DC)  (Read 1128 times)
sofakng
  • Last login:February 18, 2021, 04:19:21 pm
I'm using a Toshiba 27" (27A33) television as my arcade monitor and up until now I've only used S-VIDEO to connect my PC to the TV.  Now I plan to add a Dreamcast and this complicates things.
Normally I would add my Dreamcast to the "Video 2" jacks, but my TV is covered by my bezel so I can't use the remote control to switch between inputs.  This is the problem.
I've thought about buying an svideo input selector (from Walmart) but these seem to run at least $25 so I'm trying to avoid spending that...
Is there any other way to hookup both the DC and PC and have it switch between them without me using a remote?  Can I perhaps build something? :)
Tokey
  • Last login:June 14, 2007, 07:52:16 am
You can find a cheaper video selector on ebay I guess, but if you're looking for a free way to do it and can't spring $25 it probably won't happen.
Scott84
  • Last login:May 17, 2022, 08:24:59 pm
Your best bet might be to drill a tiny hole through the bezel.... it would be so small no one would notice.
"Computer games don't affect kids, I mean if Pac Man
affected us as kids, we'd all be running around in
darkened rooms, munching pills and listening to
repetitive music." -- Marcus Brigstocke
Hoagie_one
  • Um....whats a cabinet
you could rig the remote inside teh cab, externally wire teh buttons that change video modes and mount the buttons.  Youd still have to change batteries though.
Hiub1
  • Last login:June 05, 2011, 11:43:25 am
  • www.sleepyjack.com
Beware  of those video switchers. I bought one off ebay for the same purpose, and the SVideo quality was SO BAD! I just stuck with using the regular RCA on the back of the tv for the DC.
