Author Topic: Change MAMEWAH Controls  (Read 2437 times)
Nightmare03
  • Last login:August 18, 2007, 07:20:34 am
  • Stupid llama!
« on: January 04, 2005, 09:04:15 pm »
Hey,
I just downloaded mamewah, but i cant change the control options, i press 2 to bring up the options but i only have 3 things :
Select Emulator
Game List Options
Exit MAMEWAH
Also, i keep getting alot of errors when pressing other keys :
________________________________
PROGRAM ERROR!
An internal error has occurred - see
C:\mamewah\mamewah.log for details.
Press Any Button ('Exit' to Quit)
Just some of the log :
________________________________________________________________________________
05/01/2005 01:32:46 Error 91 Object variable or With block variable not set in CTRLR_ActivateEvent
05/01/2005 01:32:48 Error 53 File not found in frmOptions:SelectCustomList
05/01/2005 01:32:51 Error 53 File not found in frmOptions:SelectCustomList
05/01/2005 01:32:52 Error 53 File not found in frmOptions:SelectCustomList
05/01/2005 01:32:53 Error 53 File not found in frmOptions:SelectCustomList
05/01/2005 01:32:54 Error 53 File not found in frmOptions:SelectCustomList
05/01/2005 01:32:55 Error 53 File not found in frmOptions:SelectCustomList
05/01/2005 01:32:56 Error 53 File not found in CTRLR_ActivateEvent
05/01/2005 01:32:57 Error 53 File not found in CTRLR_ActivateEvent
05/01/2005 01:32:58 Error 53 File not found in CTRLR_ActivateEvent
05/01/2005 01:32:59 Error 53 File not found in frmOptions:SelectCustomList
05/01/2005 01:52:05 Error 53 File not found in CTRLR_ActivateEvent
05/01/2005 01:53:19 Error 53 File not found in CTRLR_ActivateEvent
05/01/2005 01:59:53 Error 53 File not found in CTRLR_ActivateEvent
05/01/2005 02:00:44 Error 91 Object variable or With block variable not set in CTRLR_ActivateEvent
Any help would be appreciated,
Aaron
Re: Change MAMEWAH Controls
« Reply #1 on: January 05, 2005, 05:01:59 am »
The controls must be setup manually by editing \mamewah\ctrlr\default.ini - you'll need to read \docs\ctrlr.txt...
Not sure why those errors are occurring but I have seen people get those before - I think the beta versions (available at the MameWorld ArcadeOS/MAMEWAH board) should fix these problems.
Nightmare03
  • Stupid llama!
« Reply #2 on: January 05, 2005, 10:08:39 am »
Damn, when i used mamewah before i could change the controls in the options menu...  ???
« Reply #3 on: January 05, 2005, 12:00:53 pm »
Yep, but you couldn't use multiple / simultaneous inputs, mouse input or game controllers ;)
