Author Topic: Mamewah & Vpinmame .ini requested  (Read 1891 times)
Zeosstud
  • Last login:May 11, 2026, 02:11:39 pm
« on: January 02, 2005, 03:23:27 pm »
Happy New Year All,
                                  I am trying to get Howards wrapper, vpinmame and Mamewah working.  I can test the wrapper and everything is fine.  I get the list of tables available with no problems too.  When I launch a table I see the Winners Dont Steal Roms message then stuff goes black, and stays there.  Was hoping maybe someone could post there vpinmame.ini file (or whatever you call it).
     I have vpinmame and visual pinball setup in c:\program files\visual pinball\vpinmame  pretty much the defaults I think.
Rodney
jcrouse
    • CPViewer
Re: Mamewah & Vpinmame .ini requested
« Reply #1 on: January 02, 2005, 05:17:24 pm »
You only mention MameWAH in your subject line. I will take it that your trying this through MameWAh though. What version are you using? If there is a "alt_launch_method" in the ini file for vpinball try setting it to 1.
John
Zeosstud
« Reply #2 on: January 02, 2005, 09:15:00 pm »
Fair Questions, let me try and get specific.
I am in fact using Mamewah as my front end for my arcade games, am trying to add the ability to play the pinball games from within Mamewah.  I am using the latest version of Mamewah 1.6b5 and the latest version of Mame .89 I am also using Howards Wrapper vp-launch4.exe.  Visual Pinball and Vpinmame are versions 1.5, the PC is a 2Gig P4 with 512 Megs of Ram running Windows XP SP1.
As i stated earlier, if I run the wrapper and test it, all is well.  Its only when I try to run it from within Mamewah that I hang up.  Below is a copy of my current .ini for Visual Pinball
### VPinball.ini (mamewah v1.60) ###
emulator_title                            Visual Pinmame
### List Generation Settings ###
rom_path                                  C:\Program Files\Visual Pinball\Tables
rom_extension                             vpt
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder
### Execution Settings ###
emulator_executable                       c:\program files\visual pinball\tables\vp-launch4.exe
send_rom_path                             1
send_rom_extension                        1
quotes_around_romnames                    1
long_filenames                            1
show_dos_box                              no
alt_launch_method                         0
commandline_format                        [name]
alt_commandline_format_1                  [name]
alt_commandline_format_2                  [name]
mouse_cursor                              none
### Artwork Locations ###
artwork_1_image_path                      C:\Program Files\Visual Pinball\VpinMame\snap
artwork_2_image_path
artwork_3_image_path
artwork_4_image_path
artwork_5_image_path
artwork_6_image_path
artwork_7_image_path
artwork_8_image_path
artwork_9_image_path
artwork_10_image_path
movie_preview_path
movie_artwork_no                          1
### Screen-Saver Settings ###
enable_music_in_screensaver               1
saver_type                                slideshow
movie_path
movie_fullscreen                          1
quit_delay                                30
wrapper_executable
wrapper_commandline_format                [name]
scr_file
### External Application Settings ###
ipc_file_or_path
app_1_executable
app_1_commandline_format
app_2_executable
app_2_commandline_format
app_3_executable
app_3_commandline_format
auto_launch_apps
### Additional Settings ###
music_path
play_music_during_emulation               0
lcd_display_file_path
lcd_fe_text
### Settings used by MAMEWAH ###
current_list                              0
I see now that there is an alt launch method, I will change it to 1 and report back my findings.
Rodney
Zeosstud
Working!!
« Reply #3 on: January 02, 2005, 10:58:45 pm »
Good News, Its working!!  Set all the options to 0, that took care of it.  Yeah.
Rodney
