Author Topic: Shift Button Problem (I-PAC4)  (Read 1469 times)
PiNPOiNT
  • Last login:November 19, 2010, 05:00:59 pm
« on: January 02, 2005, 01:56:44 am »
I used to have my machine up and running, but i recently re-wired everything and im all messed up again.
I'm having problems getting my IPAC/4 going with the shift button for player 3 and 4 (player 1 and 2 work fine)
here's how its setup
I have 4 player start buttons (player 1/2/3/4)
and i have a shift button (yellow)
and i want to have each player button be the mame start button (1/2/3/4)
and the shift function of each of them to be the player coin buttons (5/6/7/8)
in WinIPAC, i have each button assigned to a spot on the IPAC (start 1/start2/start3/start4)
and the shift button is assigned to player 1 sw 8 (which it is connected to on the IPAC)
so.
When i push the player 1 and 2 buttons, it fires off start 1 and start 2, and when i hold shift and press them, it gives me the shifted function of each. (good so far)
However when i push player 3 start it with only actually give me a 3 maybe 7 out of 10 times in a row, and other times it either wont do anything, or it will give me the shifted player 3 start button (7)  even though im not holding down shift.
At first i thought it was a crossed wire somewhere, but i've re-hooked it up several times.
So, few questions....
1. Should (Shift 2) in WINIPAC be assigned to the same shift button as Shift 1 is?  eg: player 1 sw 8?
2. What else could account for the strange behavior on player 3 start?
I used to have it setup so that i only had to use 1 shift button to access the shifts of all player buttons before, i dont have to have 2 different shift buttons do i?
Any other ideas?  thanks
Tiger-Heli
    • Tiger-Heli
Re: Shift Button Problem (I-PAC4)
« Reply #1 on: January 03, 2005, 10:10:13 am »
Stay with me, this will be tough to explain:
>1. Should (Shift 2) in WINIPAC be assigned to the same shift button as Shift 1 >is?  eg: player 1 sw 8?
I didn't think you could do this.  The I-PAC/4 is really more like two daisy-chained I-PAC/2's on the same board.  i.e., you can set a shift key from inputs 1-28 (P1 and P2) for these inputs and a shift key from inputs 29-56 for these inputs.
Dunno, I thought that sounded odd.
>I used to have it setup so that i only had to use 1 shift button to access the >shifts of all player buttons before, i dont have to have 2 different shift buttons >do i?
Maybe, two shift buttons would be easiest, but you could do the following (just a general example, other solutions would be possible):
Leave P1SW8 as the shift function.
Wire the Start 3 and Start 4 buttons to P2SW7 and P2SW8 inputs.
If necessary, wire the P2 Buttons 7 and 8 and I-PAC/4 Coin 3 and Coin 4 inputs.
Reprogram the I-PAC/4 as follows:
P2SW7 - "3" , Shifted 7
P2SW8 - "4", Shifted 8
Coin 3 - J
Coin 4 - L
