Author Topic: MAMEWAH - Killer Instinct CHD questions  (Read 2101 times)
stevodevo
  • Last login:March 07, 2022, 11:27:18 am
« on: December 31, 2004, 08:47:37 am »
Ok, I've got the kinst.zip and the kinst.chd in their correct locations in the directory... my problem is the game runs fine if I start it through mame32, but if I try to run it using fastmame from dos or mamewah with any mame version I get the error - u98-l15d     NOT FOUND.
How come it will work in mame32 directly but not in mamewah?  I'm using the mame32.exe in mamewah...
Thanks for the help and I hope I'm not beating a dead horse!
SirPeale
  • Green Mountain Man
Re: MAMEWAH - Killer Instinct CHD questions
« Reply #1 on: December 31, 2004, 11:04:50 am »
Since it's not finding that ROM (but seems to be finding the others) are you sure you're using a version of Mame that is compatible with that ROM set?
Also: do you mean Mame32 or command line Mame?  If the latter, get Mame from mame.net, not from classicgaming.com/mame32qa
stevodevo
« Reply #2 on: December 31, 2004, 11:18:39 am »
Thanks!  I think the rom I was using was v1.4 and the mame versions must've wanted v1.5 (which contains the u98-l15d file).  Actually, after further research I think I'm gonna run it under the u64emu emulator which is WAY faster!
Now if I can just figure out how to launch it through MAMEWAH!
