Author Topic: Perfect 360 impressions  (Read 3796 times)
jaydog
« on: May 17, 2002, 01:54:50 pm »
Goodday fellow cab builders.  I was hoping I could get some opinions on the Happ Perfect 360 joystick.  I'm building the cab mostly for street fighter.  I originally ordered a competition joystick from them, it is a good stick, but it doesn't have the springback found in the arcades.  I understand the perfect 360 is the same stick used in the arcaes. Just wondering what other people thought of it or if their are other sticks I should consider for my cab.
p.s. I understand the 360 needs a 5v power supply.  how exactly do I send power to the stick. Can I connect it to my PC? How?
Thanx for the feedback
hyiu
    • www
Re: Perfect 360 impressions
« Reply #1 on: May 17, 2002, 02:26:45 pm »
if all you're not satisfy is the spring back of the stick...
you can change the spring from a standard one to a heavy duty one... part number is 95-1309-01
you can also see it on the "Mounting & Exploded Views
