Author Topic: Mamewah game select sensitivity adjust?  (Read 1486 times)
ras2a
  • Last login:November 19, 2016, 02:21:26 pm
  • I drink, therefore I am!
    • Nolij
« on: December 30, 2004, 02:09:15 pm »
Is there a way to adjust the game select sensitivity.  Sometimes it's skips past 2 or 3 games unless you flick the the joystick lightly (seems same with keys also)?  An ini file change perhaps?
thanks
Craig
elvis
  • Last login:January 13, 2025, 08:48:40 am
  • penguin poker
    • StickFreaks
Re: Mamewah game select sensitivity adjust?
« Reply #1 on: December 31, 2004, 04:44:45 am »
You need to adjust the "sensitivity" values in the main config file (the name of which escapes me - check all the .ini files and you'll find it).  From memory these are set to 100ms.  I set mind to 250ms which stops the double-jump you talk about.
ras2a
    • Nolij
« Reply #2 on: December 31, 2004, 05:22:26 am »
OMG, the king lives! ;D...hehe.  That's brilliant, cheers mate!
EDIT: Got it: default.ini
Nice one
« Last Edit: December 31, 2004, 05:35:14 am by ras2a »
elvis
  • penguin poker
    • StickFreaks
« Reply #3 on: December 31, 2004, 05:31:33 pm »
Burger-pepsi-momma!
The 100ms option causes my setup to "double-jump" too.  That's on my iPac2-driven CP.  It only happened after a recent upgrade of my 12 month old copy of MAMEWah.
At any rate... not a hard problem to fix, so I'm not complaining.  MAMEWah is still the best cab FE period. :)
ras2a
    • Nolij
« Reply #4 on: December 31, 2004, 08:45:17 pm »
Couldn't agree more and Ste is a top bloke who is exceedingly helpful.  Happy new year!
Craig
