Author Topic: Front end question  (Read 1714 times)
magnus
  • Last login:January 16, 2005, 12:43:52 pm
Front end question
« on: December 25, 2004, 10:43:47 pm »
Keep im mind i've never delt with front ends. Anyway, when u boot your machine do have a choice of whether to load the front end os or the regular window's os or does it just start up in the front end without a windows option....
elvis
  • Last login:January 13, 2025, 08:48:40 am
  • penguin poker
    • StickFreaks
Re: Front end question
« Reply #1 on: December 25, 2004, 11:53:06 pm »
For most frontends it's a matter of just throwing a shortcut in your startup folder so that when windows loads, you boot straight into the frontend.  Some people suggest registry hacks and whatnot, but you're saving a second or two at best for the pain.
If you're cab building you don't normally want to select games via mouse+pointer style, but rather through a nice simple list that can be scrolled around via a joystick, and games started with a button press.  Hence the frontend.  How your system starts is still up to you.
magnus
« Reply #2 on: December 26, 2004, 12:27:18 am »
So how would u get it to load regular windows if the front end is in the start up folder?
Nailz
  • Last login:April 23, 2014, 08:55:03 pm
« Reply #3 on: December 26, 2004, 12:55:03 am »
????  Your OS is loaded first, and then it starts running what is in your startup folder....
magnus
« Reply #4 on: December 26, 2004, 11:47:25 am »
so it'd load your front end then u'd just exit out of it back onto your desktop? im sorry, i dont kno much about front ends....
jcrouse
    • CPViewer
« Reply #5 on: December 26, 2004, 12:00:43 pm »
Yes. Just like you if you booted to Windows, then ran an application then exited the application. You would be right back to the Windows desktop. The startup folder is kind of a special folder. After Windows boots it will execute anything (preferrably shortcuts) that are in the startup folder. If you want to run an application on Windows bootup place a shortcut to the programs executable file in the start up folder.
Good Luck,
John
magnus
« Reply #6 on: December 26, 2004, 12:21:59 pm »
thanks.. sorry, last question. so even if u have it execuate on boot up u could still just esc it out and move on to windows desktop??
ras2a
  • Last login:November 19, 2016, 02:21:26 pm
  • I drink, therefore I am!
    • Nolij
« Reply #7 on: December 26, 2004, 01:49:33 pm »
yep
magnus
« Reply #8 on: December 26, 2004, 08:11:42 pm »
thanks again....
