Author Topic: Is this a sync problem?  (Read 1608 times)
Mario
  • Last login:March 29, 2021, 08:55:12 pm
  • Mmmmm.....arcades!
    • Mario's Arcade Page
« on: December 23, 2004, 10:49:20 pm »
http://www.dalessio.ws/arcade/badpic.jpg
Thanks.
Mario
Ken Layton
  • Guru
  • Technician
Re: Is this a sync problem?
« Reply #1 on: December 23, 2004, 11:31:23 pm »
Looks like your horizontal hold is out of adjustment.
stellarola
  • Last login:June 24, 2020, 11:46:59 pm
  • .::For the love of the game::.
« Reply #2 on: December 23, 2004, 11:36:22 pm »
Also your ground wire could not be connected. I had video like before. :P
Mario
« Reply #3 on: December 24, 2004, 10:18:58 am »
Thanks. I'll check out both suggestions.
Mario
Ken Layton
  • Guru
  • Technician
« Reply #4 on: December 24, 2004, 12:00:47 pm »
You haven't mentioned the make and model of your monitor or whether or not you've had a capkit installed. Remember that some brands of monitors (like Hantarex for example) are real finicky about how the sync signal is connected.
Mario
« Reply #5 on: December 27, 2004, 01:28:11 am »
It's a 20-EZ (I hope I got that right). I have two of these in a Nintendo vs. cab that was converted into a Wrestlefest. The board's video output was split and being sent to both monitors. I have the same quality picture on both monitors.
I was told that the game used to work just fine (it was taken apart when I got it). The wires to the monitors were cut, so I had to reconnect them myself. When I did, I got the pic referenced in my original post. I couldn't find anything wrong with the connections, but I wasn't getting a good pictures. I needed help to zero in on the problem.
I didn't get around to looking at this more, yet, due to the holidays.
Thanks again for your help.
Mario
