Author Topic: For a 5 in 1 bartop what should be used in front of the monitor?  (Read 1217 times)
cursedphantasm
  • Last login:December 07, 2005, 09:03:10 pm
« on: December 22, 2004, 07:03:58 pm »
I want a real arcade feel so I'm wondering what should go in front of the monitor and would some thin Plexiglas or a clear sheet of plastic work?
Also should i use a TV for the monitor?
Hoagie_one
  • Um....whats a cabinet
Re: For a 5 in 1 bartop what should be used in front of the monitor?
« Reply #1 on: December 22, 2004, 07:25:59 pm »
i used two thin sheets so i could sandwhich artwork between them
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #2 on: December 22, 2004, 10:37:49 pm »
If you can find an RCA to VGA converter for under $80, use a monitor, otherwise it's plain foolishness not to use a TV for this application.
The 5-in-1's use RCA connectors, so if you DO happen to find a way to convert the signal to VGA cheaply, let us know.
subzero23
  • Last login:April 24, 2017, 03:21:43 am
« Reply #3 on: December 22, 2004, 10:44:08 pm »
are there adaptors that connect to a normal computer-to-monitor port that will connect to a TV?
those ones like this
to regular TV?
This user has been banned by saint and cannot reply. --- saint
paigeoliver
  • Awesome face!
« Reply #4 on: December 23, 2004, 06:52:57 am »
Yes, every adaptor you can ever imagine exists, all are expensive, and all of them degrade the image quality.
