Author Topic: how to dectect common ground with a multimeter  (Read 2243 times)
alundra
  • Last login:February 02, 2009, 09:30:05 pm
« on: December 19, 2004, 05:36:46 pm »
i want to know how can you tell which is the ground points using a multimeter..every points i measure either get nothing or 0 ohm.. even though i can tell which is the ground one by reading the trace line(mostly on simple gamepad)..but sometime this trick doesnt work on some controller, like xbox controller...thanks
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
Re: how to dectect common ground with a multimeter
« Reply #1 on: December 19, 2004, 06:08:21 pm »
I'm not sure if I'm reading your question right, but I think you're looking for the "continutity test" on the multimeter.
spongebue
  • Last login:April 20, 2006, 03:50:32 pm
« Reply #2 on: December 19, 2004, 06:17:07 pm »
generally you'd want a continuity tester, but 0 ohm = little resistence = probably ground, assuming the other point is ground, that is.
alundra
« Reply #3 on: December 19, 2004, 06:59:25 pm »
is there a continuity test option on multimeter? if so what is it lable as? there a guy told me while ago that if i get 0 ohms on the connection, then it mean the connection is good..but  that only let me know that whether my connection is good or bad..what i want to know is how to determine which is the ground point on the pcb...
i try to test a psx pcb, because it is easy to tell which is the positive and ground points..and either grounds or positive, i still get the same 0 ohm on all of them...so i really dont know how to determine the ground on xbox controller pcb...
« Last Edit: December 19, 2004, 07:03:57 pm by alundra »
lusid
  • Last login:January 04, 2016, 11:01:53 am
    • LuSiD's Arcade Flashback
« Reply #4 on: December 20, 2004, 01:07:21 pm »
If you don't have a known ground point as a reference, the multimeter will not help you.
If you can find a pin-out diagram for the xbox controller connector, that should have a ground you can reference.  From there you can use the meter to trace it back to the PCB and find the ground.
C - - - - - o
