Author Topic: exporting and saving the swatch palette  (Read 2079 times)
zorg
« on: December 16, 2004, 01:08:43 pm »
In order to make color correction/matching/modification I would like to provide my illustartor files with the corresponding color patterns I used, is there a way to provide such palette specification ??
I'm on the planning stage
Oddfeld
  • Last login:October 26, 2024, 04:46:39 pm
  • I was Jeff Minter's llama!
Re: exporting and saving the swatch palette
« Reply #1 on: December 16, 2004, 04:42:21 pm »
You can save or import a swatch library (or graphic styles, or brushes, or symbols) from the flyout menu on the side of that palette.
When you choose 'open swatch library' from that menu, you can scroll down to 'other library' to browse for an illustrator file that isn't saved in the library folder in your illustrator installation.
So, let's say you've designed a CPO that you've made a load of custom swatches for, and now you have a new document for a marquee that will use the same colour scheme - you can load your CPO file from the swatch palette of your marquee file and instead of opening up the CPO, it'll just open up the swatches you used in the CPO file as a new swatch palette. You can just use those swatches from that window or drag the ones you need into the main swatch palette for your new document to save having to keep reopening the CPO 'swatch library' every time you work on the marquee.
Same deal for symbols/brushes etc.
zorg
« Reply #2 on: December 17, 2004, 03:17:37 am »
thank's
I'm discovering new things everyday with you guys.
