Author Topic: ultrastyle v2.3 Released  (Read 1810 times)
ultrastyle
  • Last login:October 20, 2023, 09:52:29 pm
    • ultrastyle MAME Front-end
« on: December 06, 2004, 06:06:20 pm »
www.mameworld.net/ultrastyle
Changed:
- Setup buttons have been removed from the filtering tab
- changes to setup.txt to include the new Wizard info
- moved to the 7z format for the zip file
Fixed:
- The 'Other' wheel was mismatching screenshots and marquees
- External EXEs would not launch due to the fact that ultrastyle did not change the current directory
- using the boot from startup checkbox caused an error, ultrastyle now forced to use it's own directory for startup.
Added:
- Setup Wizard now guides you through setup steps
- Favorites are removable from within ultrastyle
- Added links to Catlist and NPlayers in ultraconfig
- new line in other.txt for external EXEs path
The setup wizard is the big update in this version, hopefully everyone will find it easier to work with.
Chris
itismejs
  • Last login:February 29, 2012, 05:25:43 pm
Re: ultrastyle v2.3 Released
« Reply #1 on: December 06, 2004, 06:15:34 pm »
I dont think frontends like me! :'(
First view (and error)
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #2 on: December 06, 2004, 06:35:13 pm »
Looks like you need the .Net framework. Download it here.
itismejs
« Reply #3 on: December 06, 2004, 09:43:20 pm »
Thanks that fixed it. I tried just replacing the dll with a newer version before I posted but installing the new .net framework did the trick.
